![]() | Home > Camping, Caravanning and Holidays > My new Sankey trailer build |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
I have boost's on my Sankey I ground off the lifting ring but the wheel is still tight, I however fitted 30mm spacers as that then matches the track on my truck, they fit very well. although with boost even with shims they will stick out from the standard tub as they are clearly wider. The other problem I had was that the first set of spacers I got were the fancy self centring ones and would not go over the hub but the cheaper ones would. ![]() Uploaded with ImageShack.us |
Thanks RLD.
Thanks too, Jason. As it happens, since posting my question I've discovered your trailer build thread over on LR4x4 and am about half way through reading it. All very inspirational stuff ![]() Do you remember which spacers you ended up with and were you able to just buy a pair or do you perhaps have another pair gathering dust somewhere? 30mm would be a match my truck too ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
THere was a pair for sale on here a while back - Greeni iirc left over from trailer build.
DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Any idea why the stubs are not half way between the existing ones. I can think of no engineering reason to do it that way?
Maybe that's why they were cheap ![]()
Thanks again Jason (and for the PM). I'll stop hi-jacking RLD's thread now
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
hey no it's all about trailer no problem by me
bit more done
Can't wait to see it in the flesh Ray, going to be brilliant.
![]() 110 HCPU Tipper |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i got the frame knocked up for my rapier.
how do you intend to insulate it? |
In my other trailer i did i used 6mm plate i just used rock wool but the 4 " stuff and i have had no problem with it at all i will use 2/3" stuff in this one RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Can I ask you guys about the running gear on the Mk3? Having now got mine home, it's slightly more battered than I'd hoped and is going to need some refurbishment. I don't think the brakes have been touched for years, although they do seem to work, but I'd still like to replace all of the gubbins.
I gather from scouring the 'net that the calipers and pads are from a Ford Scorpio and the disks and shocks are Defender? I'm not sure exactly which Defender though, or which end. I've also been looking into a replacement master cylinder, which seems to be the first thing that all new Mk3 owners do ![]() Any help would be much appreciated. Oh, I also need to find somebody that can do some welding as the tub is in need of a fair amount of attention too ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
i have 3 trailers and never had to replace brake parts apart from the master cylinder pot which i got from trying to remember i sent the link to KEN so ask him RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
You are correct about the calipers and pads, although I don't think the discs are land rover but a machined version of the Scorpio ones, cylinder again is an odd one but yes the shocks are 110 rears. I may still have some spare bits as I broke 2 trailers to make mine.
Jason |
