![]() | Home > Maintenance & Modifications > Door hinge bolts |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
Hello,
I like to potter around the car and do good things to it, one thing I intend to do is take out all the door hinge bolts and lube the threads so I can get them out easily in years time. I've done the back door and spare holder which is why I thought I'd ask this question before doing the rest. Are the nuts on the door bolts captive or will they fall down into the trim on a 2011 110? Can I just unscrew the bolts, lube them up then return them? When doing the spare wheel holder the bolt just went loose, had to remove the door trim to finish it off. That's no problem but I'd like notice if I have to do all that for the doors. Thanks Andy. |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
its worth buying some stainless then copper slip them and replace the originals
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Thanks for the reply, I've had a look for stainless bolt kits and they seem reasonable enough so I might as well change them over, it'll be the first change I've made! I'm guessing if I do it one bolt at a time everything will stay in it's right place and not move?
try and get some nice ones as Brendan just said nakatanenga sell them, britpart ones have horrid heads for the rear door hinges, the only ones i would buy from britpart are the front door hinges, mid row if you have a 110, bonnet hinge bolts are good from them, bumper kit is good and so are the grill and light screws, stay clear of the rear xmember bolt kit from them as they look horrid
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
What I did not say was that we stock the Nakatanenga screw sets ![]() Brendan |
will you be taking most bits like this along to the lro show this weekend, im also interested in a snow wing cover if you got any that is- ill be bringing my European passport (yet to be made) to get it vat free
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
Can you post a link to them in your shop, I can't find them. Thanks |
Thanks Brendan,
Can you do me a quote for the Nakatanenga boor bolt set and another for the various other bolts around the car that need changing, bumper, cross member and any others you'd advise changing (2011 110xs). Thanks Andy. |
If you are replacing the door bolts with Stainless it is well worth fitting some that require a different tool to remove than the standard Land Rover ones from a security point of view IMHO
Hopefully will have some stainless bolt kits including original heads with us at Peterborough.
Knowing one of the methods of stealing the doors different headed screws would not help. Brendan |
