Home > Technical > Bluetooth OBD Reader
Page 2 of 3 <123>
SimonR
Matt, keep us posted on whether it works on iPhone!
Si
Post #166142 3rd Sep 2012 4:31pm
x-isle
Inigo wrote:
I got one of these a while back and it stopped working after 2 months, the LED is still lit, but I cannot connect.
The Torque website seems to suggest that these ebay cheapy bluetooth adapters are a bit hit and miss. Unfortunately, the ones they do recommend are around £200.
I wouldn't recommend a garage outfit using these, but for the occasional user, thats 20x £10 ones for the same price. Can't see going through 20 of them in my lifetime. Mr. Green Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #166143 3rd Sep 2012 4:37pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Defo let us know if works on the iPhone, if it does it's another one ordered! Darren
Post #166156 3rd Sep 2012 6:22pm
T1G UP
i just ordered one
Post #166174 3rd Sep 2012 7:35pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
This looks great but I have an older 1999 td5 I'm guessing it won't work with that?
Post #166180 3rd Sep 2012 8:03pm
x-isle
Not sure that your's will be OBD2, if not, it won't work unfortunatly. Craig Rogers
2007 Puma 110 XS
Post #166262 4th Sep 2012 8:10am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
My unit arrived, but as predicted it doesnt work with my TD5 Defender so far. Sad
I'll look around the inter-web for confirmation.
cheers
simon
Post #166554 5th Sep 2012 5:27pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
It won't work for any live data from the TD5, the standard codes may be able to be read but that is it.
Post #166579 5th Sep 2012 8:08pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
the wifi ones work better with iphone (unless you have a jailbroken one) as the iphone bluetooth is very restricted.
Post #166752 6th Sep 2012 5:45pm
Mine arrived today but I don't seem to be able to connect to it. Big Cry
I am using an HTC phone and torque pro on an 07 Puma. With the interface device in the socket and the ignition on, I get a "paired but not connected" status from the Bluetooth manager and torque says that it isn't connected to the OBDII device. Nothing I do seems to make a working connection.
Any ideas anyone? Faulty device? Faulty socket?
I did try it also on my 02 Td5 Disco knowing it may not work but thinking it should at least power the device and allow pairing but it is exactly the same as on the Puma.
Any help gratefully received, thanks.
Post #166779 6th Sep 2012 7:14pm
Ok, cancel the SOS! Just fiddled about some more and it's started working. I didn't do anything different and I suspect it may have been caused by a poor connection in the socket or something like that.
A great little tool for £13 or so!
Post #166789 6th Sep 2012 7:47pm
Naks
blackwolf wrote:
I am using an HTC phone and torque pro on an 07 Puma. With the interface device in the socket and the ignition on, I get a "paired but not connected" status from the Bluetooth manager and torque says that it isn't connected to the OBDII device. Nothing I do seems to make a working connection..
I had the same issue.
You must go into Torque > Settings > Device and then select the device, which must already be paired with your phone. --
Post #166876 7th Sep 2012 11:11am
roel
Did anyone get it working on a TD5? Roel
2003 90 Td5 (2009-now)
Post #169696 21st Sep 2012 3:11pm
couplands
No, not me....I looked on the interweb, but couldn't find any evidence it would work....
Simon
Post #169698 21st Sep 2012 3:16pm
Naks
Yeah, the Td5 is a funny one. AFAIK, only the Hawkeye and Nanocom work with it. --
Post #169704 21st Sep 2012 3:55pm
Page 2 of 3 <123>
