Home > Puma (Tdci) > exhaust manifold allignment |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
edited
2nd Sep 2012 10:58am |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Some pictures
[ Click image to enlarge] [/ Click image to enlarge] [ Click image to enlarge][/img] Best regards Christian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
2nd Sep 2012 11:09am |
Just a thought - could it have been caused by driving with faulty wiring to turbo?
And if I need a new manifold - is that obtainable from Ford - or is it special for the def. Best regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
2nd Sep 2012 11:20am |
I was thinking about cutting the gasket in two - thus allowing it to fit. Drilling the holes a bit, and machine the openings in the two inlets near the turbo ( it is those two that has "warped"). That will cause the holes for the bolts to be bigger than the bolt itself - do not know if that will be a problem. Any ideas?
Still worried about what could have caused that much heat? - Best regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
2nd Sep 2012 4:47pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
I think it is probably a combination of things, not just one.
It is worth de-catting the vehicle, as I'm sure this alone is the biggest issue. Hot exhaust gasses can't get out past the turbocharger fast enough because of the back pressure leading into the cat and the standard exhaust system. Now, with this, any rapid cooling (anything from water immersion to driving down a long hill with foot off the throttle for a while) will cause the manifold gasket to leak, and perhaps this is more of an extreme issue in your part of the world? |
2nd Sep 2012 8:16pm |
