Home > Td5 > Fuel pressure regulator leaking....
Gareth
I noticed a strong smell of diesel after a drive this morning. I have just had a look under the acoustic cover and the fpr is leaking. It looks easy enough to change, and have already ordered a genuine parts replacement.
I notice that there are repair kits available, and was wondering if its worth reconditioning my leaky one and keep as a spare? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #165758 1st Sep 2012 3:21pm
There are kits in eblag, a bag of O rings.
If you google it, there is a couple of hits that come up with folk who have repaired them.
As to long term reliability on a repaired one, I don't know.
edit: ebay link to repair kits
Post #165766 1st Sep 2012 4:12pm
my td5 went after 60k/7 years, common problem, easy fix and saves you £££ in diesel. Nice thing about td5's is apart from the fuel pressure regulator and injector seals, the engines are bulletproof Thumbs Up
and they sound so much nicer than a transit Mr. Green
Post #165784 1st Sep 2012 5:37pm
Gareth
Cheers. I think I will skip the rebuild, if it goes again I'll just buy another one.
I agree with your TD5 comments, I think its a very sweet engine, and sounds really nice. Mine has only done 52k, buts its 10 years old now. No oil leaks, and still runs well. Maybe I will replace the MAF sensor next to try and cure a little laziness to get going when its cold. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #165799 1st Sep 2012 6:07pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Yes - my FPR has also started leaking. If its the same thing were talking about at the back of the engine, I've tightened it and it's stopped leaking !
Monitoring it - if it stars again will order a new one......
More worrying the rear half shaft broke tonight for no apparent reason !
Changed my MAF again last weekend and removed the EGR - feels like a new engine again ! 2007 TD5 90 Hard Top
Post #165825 1st Sep 2012 8:22pm
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
I just clocked over 160,000klm (2004 Td5) and notice mine started leaking, put a ebay kit in it about 2 weeks ago and it just started leakng again on Friday (after about 2000klm) . Have just fitted a genuine replacement. Would only consider genuine next time
Post #165895 2nd Sep 2012 10:37am
