Home > Maintenance & Modifications > Fitting Entreq door strips
Page 2 of 2 <12
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I don't think I'll be getting any of them in a hurry then Neutral I'd have run out of patience on paragraph one and looked them into the hedge, good on you for keeping at it though. I'll bet it looks smart now you have done it , pics when you can.
There do seem to be some overlap between 11 and 12 model years, like mine has the fuel filler leash (that's how I can tell em apart said my salesman - that theory went out the window when mine turned up from LR) and also my door strips are painted body colour and seen a 90 of same year with a galvanised? Metal door strip - I believe I have the chubbier 12my years seats as well, but not compared any earlier ones.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #165424 30th Aug 2012 8:08pm
jerseyman
Thud wrote:
Lets have a look at the pics then.
i will try and take some tomorrow.
Post #165426 30th Aug 2012 8:11pm
jerseyman
Some (rather poor) pics as promised. Does not look as if I shampood and vacuumed the carpets and cleaned the mats but I had. Also highlights that the carpets fit where they touch
Right hand side, fitted under carpets.
Left hand side fitted over carpets
Asymmetry rules!
Post #165689 1st Sep 2012 8:57am
Like the left hand side better and it's doing "more" of what you bought them to do on that side.
Does sound like it was a right faff though, so will probably be giving it a miss on mine.
Thanks for sharing in full detail. Really useful post for others.
Post #177785 21st Oct 2012 8:31pm
JonM
Hi. I started to install the door strips but ran into a few questions
- does the plastic washer go in the inside or the outside of the truck? I was thinking outside to protect the aluminum from the stainless but... I don't know
- where does the rubber gusset go? On the inside or outside seem?
- where does the compression band go? On the inside lip or outside lip?
Do you have any pics of the strips installed?
Post #259530 18th Aug 2013 4:56am
leeds
With any aftermarket gear getting it to fit with other aftermarket gear can be fraught with issues. Then we have the famous Land Rover build quality to contend with. Embarassed
Land Rover has changed the design of the door seals as well.
Also Entreq has changed what comes with the door strips as well.
If your vehicle has the post autumn 2011 seals fitted to the bottom of the actual door then you do not need the supplied rubber gasket. This rubber gasket fits on the bottom of the door strip as in the photo below
If your vehicle is fitted with the latter design door sill I would use compression tape behind the vertical face of the door strip to slow down water/dirt ingress behind the strip
The compression tape can also be used under the strip inside the vehicle to take out any irregularities in levels.
Plastic washers can be used as spacers underneath (fiddly) strip or on top under the stainless washers.
Use a bit of paste on the fixings as well
Have fitted them to the white 90 without any major issues.
Brendan
Post #259588 18th Aug 2013 11:07am
theorangebandit
Brendan
i was going to make door strips like this, i was gonna use chequer plate but they look fantastic . although im yet to see the cost, as with most shiney additions for the defender they are a little pricey
Post #259604 18th Aug 2013 12:55pm
Merlin
I'm interested in the metal work behind your LH seat. It looks like it is galvanised. Mine is just black paint. Is this another change LR has made, or is it a case of "fit what we have to get it out" ? BTW mine is MY07.
Merlin
Post #259843 19th Aug 2013 11:51am
jerseyman
Hi Merlin I have just spotted your post. I think you must mean my photos? The metal work isn't galvanised but is "body Colour" in my case Zermatt Silver. It is one of the last 2.4s, a 2012 car but MY11
Brian
Post #260960 24th Aug 2013 11:00am
Page 2 of 2 <12
