![]() | Home > Wheels & Tyres > Spare tyre compatibility |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2473 ![]() ![]() ![]() |
I believe they are the same diametre. So, yes. Puma 110" SW
Try this,
http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Willie Member Since: 08 Oct 2009 Location: Stockton Posts: 48 ![]() ![]() ![]() |
Thanks Fekete,
Tried web site but couldn't put in 7.50 R 16 tyre size, but could see how calculator worked. Thamks Willie Defender Virgin |
Just measure it.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
As a spare it will be fine- but when I say spare it will be ok to drive to the nearest garage to get the other repaired
Glyn |
Thanks for the responses everyone. Just one thing more, when I got the wheels they came with wheel nuts. Only thing is there are two different types, one has a dimple on top of the stainless cap the other is flat. Are they the correct fitments? they look slightly different at the screw but both have the correct thread and fit a 27mm wrench.
I will try to post a picture latter. Willie Defender Virgin |
It mite be that the one with the dimple is the locking wheel nut, see if the one with the dimple on it, That a cover pulls off it
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
The ones with a dimple are the locking wheel nuts, the stainless outer that has the dimple is just a cover that pulls off
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Yup - the dimple signifies the security bolt. Have you got the correct security attachment? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
Thought of that, but the covers wouldn't come off. I will try to pull it off (if you pardon the expression) a bit harder tomorrow. The nuts didn't come with a locking/unlocking key.
![]() ![]() ![]() ![]() Glyn |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I you can't remove the cap with the useless black sleeve simply turn it with your wheel key and it will come off (in your hand)!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Despite all the pulling and twisting the caps do not come off. I have measured them using a vernier and the dimpled (10 off) and the flat ones (13 off) are both the same - 27mm head, 29mm round shoulder and same thread. I can only assume they are an after market version. Looks like I will have to purchase a set of locking wheel nuts. Defender Virgin
