![]() | Home > Maintenance & Modifications > Painting Defender chassis |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Excossack
impressive efforts, I bet you are aching as per K90 when you are finished Id spray it all with dinitrol, it will cover the bits you may have struggled to reach and creep into any cracks (especially if you thin it slightly with white spirits) the finish you get from dinitrol will smooth the brush marks and make the whole underside uniform it realy is great stuff, I use waxoil on my last landrover but having now used dinitrol I would not go back, its also dead easy to touch up out of a can DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6006 ![]() ![]() ![]() |
Something like this
http://www.ebay.co.uk/itm/3-x-DINITROL-447...4ab881b080 or http://www.ebay.co.uk/itm/4-x-DINITROL-494...3376d72a1b 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
John
I think I used 4941, Its worth going onto thier website as well think its "Rejel" in the serch engine all the best Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Cheers Rob, I will have a look on the Rejel website.
Today I got the last section of the chassis done! This is one job I don't want to again in a hurry! Hopefully the Dinitrolling will be a bit easier (but could be messier!) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 ![]() ![]() ![]() |
Nice work. I have recently done the chassis of my landy. It's not a nice job to do, but the result is well worth the trouble if you ask me. And it should prevent a chassis change for the next 25 years
Cheers. Its taken quite a few hours of hard graft. So far I think i have gone through
0.5 litre bottle of Jenolite (just started a 2nd) 1 small can of zinc primer 1.5 litre of chassis black .5 litre of etch primer Several cheap paint brushes from Wilkos A couple bottles of white spirit for degreasing Several old rags Quite a few pairs of disposable gloves Replaced all the bolts that hold the mud flaps to the chassis and the ones that hold the mud flaps to the brackets with stainless.Still got a few more to replace Lots of coffee and nibbles 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44 ![]() ![]() ![]() |
Good job mate! I plan on doing mine at some point, although to be fair Landie chassis' do seem to fair better over here in Oz, rust not being half as bad a problem as back in the UK.
Probably helped as well by Councils over here not putting bloody salt on the roads every winter. Col. |
Cheers. Its turned out OK, there are bits I have missed either through doing the job lying on my back or very awkward bits that would be easier with the body off etc. Overall I am pleased with it. I would like to get it under-sealed before winter.
Road salt doesn't help.! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
