![]() | Home > Spotted > 2005(!) Puma Van |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Could it be a custom plate?
Glyn ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Could be TD5 with personal plate and changed bonnet. Depends what you're meaning of console is?
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I read 'console' as 'Dash' and the way it is mint would indicate to me that the plate says something/ links to business. I couldn't imagine someone going to that much trouble as it would cost more to do the work than buy a new/ nearly new truck.
But then again......... We ArE aLl CrAzY aRoUnD hErE ![]() Glyn ![]() ![]() |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Customer of mine had one as an testing vehicule. He was an engineer at the factory. It was basically a td5 with a puma engine.
Glyn - I did think that but thought it best to check all the same
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Yes, I meant dashboard, the "nostril" Ford vents being giveaways. The plate didn't look intentionally personalised (unless the owner's initials were in the last 3 letters), started WD05 IIRC.
Was there an early Ford-ownership, pre-Puma motor time, when they were using up TD5 components, but putting Puma bonnets & dashboards in? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
