Home > Maintenance & Modifications > Bonnet-mounted spare wheel
Page 3 of 3 <123
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
bonnet mounted spare on puma,
Post #164080 24th Aug 2012 3:49am
ericvv
Post #164083 24th Aug 2012 5:24am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
I really could not get on with my spare up front so I now carry tire weld and only sling the spare in the boot if I'm trailering a long way from home. Rhubarb and custard let fly with their secret weapon.
Post #164086 24th Aug 2012 6:53am
Glynparry25
Be carefull with this.
If you get a nail through the tread it can be a �10 repair and off you go- if you use tyre weld this isn't possible without rediculous amounts of cleaning which means a new tyre which is closer to �100-150.
I hate the space the spare takes upo in my DC but know it is worth it as 285 BFG KM M/T sell for aboput �130 each here (never mind the �150+ in UK).
Glyn Dog Sheep
Post #164093 24th Aug 2012 7:43am
Glynparry25
Another option:
Technically it is better for a collision with a pedestrian as his head would bounce off the inflated rubber? Whistle
Glyn Dog Sheep
Post #164095 24th Aug 2012 7:49am
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
Quentin
any chance of a shot from the drivers perspective and another external shot from further away.
is that wheel carrier a bespoke item or something off the shelf?
shaun
Post #164108 24th Aug 2012 9:23am
quentin
shaun.mobile wrote:
Quentin
shaun
You might have to ask Mudstuff, I found the images on their website, other images below but none found looking out the window. Might be OK if you sit on a cushion Confused
Post #164115 24th Aug 2012 9:42am
Naks
Glynparry25 wrote:
Another option:
I wouldn't do that, esp seeing how the Puma already suffers in warmer climate with its intercooler. --
Post #164117 24th Aug 2012 10:10am
Glynparry25
I couldn't help but go to the workshop and put the spare on the bonnet of mine.
After fitting I assumed this possition: Rolling with laughter .... after 2 mins I picked myself up and took some pics that I will post later when not on work computer.
Looks meaty, but you can't see Fu*k all through the windscreen. The thought of then having a bracket as posted above which will then add another inch or so height would make it even worse. With a 285 directly on the bonet lump, it obscures about 50% of your view (add another inch and you will loose 60-70% usefull visability)...... Then there is the legal implications of the bracket- the bar across the front is in direct violation of the 'bull bar' rule.
I can't see why it would be a problem. It is a constant 30+ Degrees C here and I am running a TJM bull bar and Lightforce 240 spots and not had a sniff of temp/ power problems. It seems only some suffer from the problems.
Glyn Dog Sheep
Post #164125 24th Aug 2012 11:08am
Glynparry25
Here it is..... make your own mind up!
Glyn Dog :sheep:
Post #164179 24th Aug 2012 5:35pm
Captain Speaking
2008 Defender 90 Puma 2.4 CSW Tonga Green
Yep, thought so - love it. Nice pics guys.
Right, now let's see what my garage says about actually fitting it on... Shocked
Post #164260 25th Aug 2012 12:32am
Interesting thread - learnt a few things and never seen a spare mounted on a puma bonnet before. Used to run a Lightweight with a wide section BFG bonnet mounted and surprisingly never thought I had an issue with forward visibility but whenever someone else jumped in to have a drive the spare immediately became an issue.
Two military options for consideration - the Wolf fitting - has anyone got any pics fitted to a civvie model?; and the old Pink Panther fitting:
Whilst looking it up, I also came across this double fitting for the front - given it was an Oz bush patrol vehicle cooling must have be OK:
and this these two to add:
Post #181921 4th Nov 2012 11:56am
Page 3 of 3 <123
