![]() | Home > Puma (Tdci) > Question regarding Corrosion Warranty |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
If you have a rusty bumper, under the Corrosion Warranty do Land Rover have to replace it or re-paint it? LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Replace!
![]() Treat every day as if it is your last....one day you will be right!! |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
good to know. I have a rusty bumper and the side steps have started to bubble... BM52
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
They are under no obligation to replace they can repair/paint it if they like, but in reality they will replace as its more cost effective, I,e one off one on 30 minutes work as opposed to several hours prep , paint etc.
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 ![]() ![]() |
My bulkhead has just been stripped, primed and re-sprayed no question on a 10 plate!
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
mines booked in for bulk head work too......
my only concern is how long it'll be before it starts again. |
Tons of waxoyl Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
if only it were that simple. the rust is bubbling from underneath the paint and there doesn't appear to be any defects in the paint to let water in so not sure the way oil would help any?
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1279 ![]() ![]() |
My bumper is rusty when I look from the inside.......
It looks ok from the front..... Do you think that would be replaced too? Cheers |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 352 ![]() ![]() |
It should be and I bet the fixings are shot at as well. Proud owner 110 Utility XS Ex RR Sport HST V8 Ex Td5 90 |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
Mines going back in a few weeks for a faulty central locking issues and the side tubes are rusty as hell at the front - will these be covered (2009 model, bought from LR dealer etc) ? Cheers,
Superspoons |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
The best thing to do with the bumper is take it off, sand it down and repaint it with layers of better paint then put it back with stainless bolts.
Yes..eventually..when it's down to you..
But whilst it's under LR warranty I believe they should replace all corroded parts. Sometimes you have to push..but they will if you do |
skiboy Member Since: 14 May 2012 Location: milton keynes Posts: 21 ![]() ![]() ![]() |
my 2010 XS is in at the minute, rusty bulkhead, leaky front windscreen (as standard)
