Home > Maintenance & Modifications > Front propshaft issue with defender 110 td5!!
Welshsurferdude
Wales
Hi there
I have a Defender 110 crew cab on a 02 plate with a 2" lift. it also has 295/95/16 tyres with spacers.
They said that the front prop is worn/noisy and its a Disco 2 TD5 prop with double cardons and needs a new one so I ordered the following
http://www.island-4x4.co.uk/propshaft-fron...-1179.html to replace it.
got delivered this morning
But the garage says this doesn't fit.
Whats the issue here?
I can't go see the car as Im stuck at home with a broken foot!
whats the correct prop or advice on the best prop?
Many thanks!
Kenny 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #163748 22nd Aug 2012 5:29pm
The Disco Td5 prop uses a different sized drive flange on the transfer box. It's bigger (in diameter) than the one that will fit the propshaft in the link you posted.
You just need to get a "normal" Td5 defender drive flange for them to bolt in place, which is either FRC5442 if you have a 32D suffix transfer box, or a IEC100020 if yours is a 43D suffix (I don't know what the difference is between then, I though they were all the same!)
And beware of the propshaft you've bought... looks l ike a Britpart one.... best carry a spare!
Post #163796 22nd Aug 2012 8:10pm
Porny
Site Sponsor
If you've got a 2" lift... I wouldn't replace the propshaft with a wide angle version, I'd get another double cardon version - as per the Td5 Discovery one.
The wide angle one is good for droop, but with a 2" the working angle of the UJ when on the road will be too much, and you will get a vibration.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #163891 23rd Aug 2012 7:25am
Welshsurferdude
Wales
Thsnk you for your advice boys!
I thought this might be the case! 2011 Santorini Black USW XS.
Post #163893 23rd Aug 2012 7:55am
