![]() | Home > Puma (Tdci) > Injector Rattle Now Sorted |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Got our baby back from dealers with an ECU update that has finally shut the noise from the injectors.
![]() Also had them admit that the clutch is again to blame and they have sent complaint to the UK for further advise. They sorted the fuel leak at the tank with a new seal at the sender unit although they seem to keep calling it a fuel pump. I assume they know there is an engine mounted fuel pump on the Puma. Anyway will have to fill the tank to check on their workmanship. All's well in landy land so I can smile again. ![]() ![]() Series III 1973 - going strong |
Same here
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
Yes, they call the fuel pickup pipe a "pump", have done for years.
