Home > Technical > Removing transfer lever on Puma
How do I go about removing the transfer lever on a Puma ?
Post #163417 21st Aug 2012 10:08am
There was a similar thread on this a while back, SEARCH brings this one up....
Post #163546 21st Aug 2012 8:00pm
No mention of removing the transfer lever though Confused
Post #163549 21st Aug 2012 8:18pm
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Re: Removing transfer lever on Puma
Remove carpet around tunnel
Lift up gaiter from around levers
Remove gear lever by uncliping at either side at the bottom
Pull off transfer knob, remove gaiter and gear lever
Remove foam
Undo the four torx head screws around transfer lever
Unclip the ball joint off the lever
Lift out
Hope this helps
Post #163554 21st Aug 2012 8:35pm
You are a star Bow down Thank you
Great to meet you at Billing Thumbs Up
Post #163556 21st Aug 2012 8:37pm
sense of adventure
If that doesn't make sense call me and I'll talk you through it 07714419998 any time
Post #163558 21st Aug 2012 8:42pm
Saved Number to contacts if you wanted to delete from thread - Thanks very much for the offer, hugely appreciated
Post #163563 21st Aug 2012 8:46pm
sense of adventure
It's everywhere anyway
Post #163566 21st Aug 2012 8:48pm
K9F
Is replacement of the Transfer Lever as simple as this post implies?
I have just received an SVX one I purchased from a fellow forum member and was wondering if there is enough access from within the vehicle to disconnect/reconnect the linkages or does this have to be carried out underneath the vehicle where access is limited?
As Go Beyond stated Diesel Jim's link is just for the Gear Lever not Transfer Lever.
Any information would be gratefully received for any 'pitfalls' I may encounter before attempting the swap out? I could call the number above but my late dear-departed Mother always told me 'Not to talk to strangers.' Also if his phones are like mine I get enough cold callers as it is! I have also sent a 'pm' to Go Beyond.
Thank you. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #168152 13th Sep 2012 7:20pm
dgardel
Italy
Thank you.
Mal,
you have an email!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #168229 13th Sep 2012 9:59pm
can't wait to see your xfer knob sunday Mal Thumbs Up
Post #168233 13th Sep 2012 10:10pm
K9F
Thanks Daniele..... Thumbs Up
Lots on at the moment.....You can see my knob anytime!!! Shocked Shocked Rolling with laughter
Probably still be in it's box though. Woodburner chimney/flue to sweep and new cowl to fit first. St Malo next week so probably won't get fitted this side of October. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #168266 13th Sep 2012 11:47pm
sense of adventure
Plenty of room and I have big hands.
Post #168270 14th Sep 2012 12:15am
K9F
Reassuring, thank you. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #168283 14th Sep 2012 6:02am
Hi Mal,
Thought I'd reply to your PM on here for the benefit of others.
As you've probably worked out, I wanted to know how to remove the transfer lever so that we could cover it in leather, however I have discovered it's not necessary to remove any of the under floor gubbins as the standard lever can just be pulled off !
I suspect you could do the same with your SVX lever (if you wanted to)
HTH
Post #168315 14th Sep 2012 9:03am
