Home > Maintenance & Modifications > How can I lower 1st gear in high box on a Puma?
BigWheels
When going on a LR Experience treck, one of the LR guys said that one of the reasons TDCis have anti-stall fuel jetting is because 1st gear is higher than on TD5s (& TDis?).
This might explain why some farmers prefer pre TDCi model. They can't stay in high box 1st gear while following flocks & herds down a lane.
What can be done to help actually or simulate a lower 1st gear in high box, (without going into lower box, clutch slipping/s & snatching) on a TDCi? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #163323 20th Aug 2012 7:39pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Get faster sheep .......... sorted Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #163325 20th Aug 2012 7:49pm
ericvv
Post #163328 20th Aug 2012 7:50pm
spudfan
Ireland
The first gear in my Puma tdci is lower than in the tdi. One of the complaints about the td5 when it came out was that first gear was relatively high and some people were inclined to stall it. The Puma tdci was fitted with a lower first gear to get around this and it is suited to taking off with a trailer with no bother at all.There was a thread on this site sometime ago about people avoiding first gear in the Puma and taking off in second.Try first gear low in the Puma, it is an experiece! I don't think the anti stall was fitted to compensate for the Puma tdci first gear. Some of the techno inclined blokes will come on to give you the full briefing on that. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #163330 20th Aug 2012 8:00pm
dgardel
Italy
Re: How can I lower 1st gear in high box on a Puma?
Fired!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #163359 20th Aug 2012 9:16pm
LR90XS2011
Im led to believe the idle jack (anti stall) was fitted because low first is so low that it can be dangerous on decents, this is because without it the wheels dont rotate quickly enough to stop the car sliding. Personally I like the fact the car becomes almost unstoppable in low first DEFENDER 90 TDCI XS,
Post #163361 20th Aug 2012 9:18pm
Gareth
TD5 has anti-stall as well. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #163363 20th Aug 2012 9:22pm
T1G UP
not sure on ratios of the 6 speed but a tdci has a higher ratio TB. 1st gear is to low IMO. with some larger tyres on it would be better and i use the 2nd gear no throttle take off alot more now on the flat or down hill.
Post #163368 20th Aug 2012 9:46pm
Idle jack and anti-stall are completely different functions for completely different purposes. Your description of the idle jack is correct, but that isn't anti-stall.
You could lower a Puma's ratios by fitting a Td5 transfer gear set, but overall it would be way too low and probably dangerous on steep descents with poor adhesion.
Post #163377 20th Aug 2012 10:51pm
fixit
There is a lot to be said for driving downhill when its slippery as the wheels won't slide as easy then
I have only driven a puma defender a couple of times but it is lower geared than a tdi IMO
And most of the farmers i know who have them use second to pull off unless towing
Don't know about following sheep though Whistle may be they are lame Rolling with laughter
Post #164188 24th Aug 2012 6:35pm
fixit
ericvv wrote:
Must have been smoking dope Rolling Eyes . 1st gear on a Puma is lower than on a Td5.
Guess this was the LR Experience guy who said something like that? Rolling with laughter
That some pretty good Censored man Dog Laughing Laughing
&feature=related
Thats a better clip
I aint seen that in 20 years Wink
Post #164193 24th Aug 2012 6:54pm
jst
does a higher gearing not give a lower speed?
1st gear in a puma is 33% slower than corresponding 1st gear on R380/LT77.
6th is 22% higher.
if the end result is you want to go slower in a TDCI then fit a 1.4 or 1.6 Tbox or 4.11 diffs. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #164379 25th Aug 2012 8:06pm
jst
i also think you are getting anti stall and idle jack mixed up.
idle jack comes in when you are in 1st low range to raise the revs to 1100rpm for the reasons as above wrt to descents and not having too much engine breaking.
anti stall works in all the gears. its more beneficial and noticeable in the lower numbered gears. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #164380 25th Aug 2012 8:08pm
