![]() | Home > Puma (Tdci) > Swivel |
Hi boy i've had 3 swivels replaced, And 1 swivel ball the swivel ball had a machine mark in it which made 2 of them leak the other 1 just must of got
![]() ![]() All replaced under warranty NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Thanks buddy, just rang them and I am booked in on the 19th. Hope there is anough oil/grease in it to last that long.
![]() Boy |
Hi Justin,were have you been hiding? it doesn't take much for something to damage the wiper seal when off roading and it's covered by the warranty. ![]() 1968 1/32 scale Britains 109 Pick up. |
Did some offroading in spain (mostly dusty tracks) a couple of months ago, some gental green laning last month and last weekend went to Exmoor with the LRA crew but all we did was ariver crossing at Tarr Steps. The seal seams to have gone at the rear most point of the ball. Maybe a small stone/grit got in?
Yes there should be and if not on inspection the dealer will sort out if it has caused any other damage i've ran 3 weeks with 1 leaking ![]() The other thing is make sure that the brakes haven't been comtaminated NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Can I ask how does one check the level of grease in the housing and how do you refill it? Puma 110 - gone
Series III 1973 - going strong |
Square head plug on top of the housing for the oil James. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
You can not check the level. Puma 110" SW ............................................................. Earth first. Other planets later |
