Home > Puma (Tdci) > Puma engine cuts out
Ironman
2009 Defender 110 Puma 2.4 SW Bonatti Grey
Puma engine cuts out while driving on tar road
No warning lights,no overheat , no nothing? Diesel
Half tank, oil is fine 38 000 km on clock!!!
Dont start at all ,how do u bleed the feul system if u are in bush
Post #161967 14th Aug 2012 8:50pm
dgardel
Italy
Check the main relay socket and the fuses sockets/connections Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #162005 14th Aug 2012 11:01pm
MK
Re: Puma engine cuts out
With an inboard compressor into the fuel tank and open bleeding valve. There is also a special manual pump (search on this site or google it) Puma 110" SW
Post #162018 15th Aug 2012 3:24am
Naks
Sounds like the engine is not getting enough diesel?
Drop the tank and check that the fuel pickup is not clogged - not uncommon for this to be blocked especially if you have filled up with some dodgy diesel.
Also check the fuel filter (in the driver's side rear wheel arch) --
Post #162048 15th Aug 2012 9:28am
