Home > Maintenance & Modifications > Leaking rear side windows
excossack
In the rear of my 1999 110 I have sliding windows. All good apart from the leak and the rattle when I just the doors (the rattle I can live with for now) its the leak that I would like to fix
The leak appears on the plastic trim below the window and is in the middle, almost inline with the middle upright.
Is this a know feature? and hints and tips on fixing the leak? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #161981 14th Aug 2012 9:32pm
Killer90
Site Sponsor
could you get some close up pics posted up, could be getting in around the top part or even were the two pieces of glass meet Thumbs Up stand there with a hose and try different parts youll know when it leaks and then atleast you know were its coming in from Thumbs Up two man job though one inside and one with the hose CSK Automotive
www.cskautomotive.co.uk
Post #161984 14th Aug 2012 9:38pm
excossack
I can do when it rains next or tomorrow, which ever is sooner., A bit late to grab the hose and give the car a wash!
I get a feeling its were the two windows meet up. 1999 Defender TD5 110
Regards
John M0VAZ
Post #161986 14th Aug 2012 9:43pm
Killer90
Site Sponsor
may need a new felt for it Thumbs Up MWC7652 thats the part number for it Very Happy CSK Automotive
Post #161991 14th Aug 2012 10:02pm
excossack
The felt in the bottom corner has fallen apart... 1999 Defender TD5 110
Regards
John M0VAZ
Post #161992 14th Aug 2012 10:10pm
Retroanaconda
Do you ever use them?
Back when I had a truck cab years ago I just sealed the sliding window shut with silicone in the end, as the rattle was annoying me and I never opened the damn thing.
When I come to put my 110 back together I'm just going to replace those rear windows with solid glass, can't see any reason to have them open unless you have passengers back there.
Post #162001 14th Aug 2012 10:51pm
excossack
They do get used but not very often. Mainly when I am on rallies when parked up and its too windy to open the door windows or when I have mast up and need the wire into the vehichle. 1999 Defender TD5 110
Regards
John M0VAZ
Post #162030 15th Aug 2012 8:05am
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
As said by others, a rattling sliding pane is probably down to knackered felt channels - You'll have fun replacing those!
As far as the leaks are concerned, and at risk of stating the obvious, are the drainage slots in the window frame blocked up with cr@p and causing water to overflow into the vehicle? Is the vertical rubber seal that should be located between fixed and sliding window panes damaged or missing? Pictures would help with diagnosis. '57 Defender 110 XS Station Wagon 2.4tdci
Post #162127 15th Aug 2012 3:48pm
excossack
I might have to investigate the felt option at some point
As far as I can tell the vertical rubber seals are correct and OK, Will post a picture.
The drain holes look OK to me. 1999 Defender TD5 110
Regards
John M0VAZ
Post #162221 15th Aug 2012 10:24pm
excossack
Here is a picture of the leak
I noticed that the side panel was also wet and a closer look revealed that if I pressed the panel below the section where the bolts are, I get some water flexed/pumped out the joint.
The leak is the same on the windows on the other side of the car but could not see any water escape from the same joint
Both panels have been left off incase of more rain overnight and I will have another look. 1999 Defender TD5 110
Regards
John M0VAZ
Post #162226 15th Aug 2012 10:34pm
excossack
Here is a picture of the side window seal
Regards
John M0VAZ
Post #162355 16th Aug 2012 1:33pm
barjout
Canada 1996 Defender 110 300 Tdi SW Alpine White
Good day.
Mine used to rattdle as well and they are now fixed. Instead of using the original felt I went toward the window channel option. http://www.woolies-trim.co.uk/c-290-single-track.aspx. In order to fix the rattle I had to take them off the vehicle. The screw that old the bar in the middle of the window with the rubber seal is what fix the rattle. It got loose with time. You can tight the bottom and top screw to the point that you wont be able to slide the windows anymore. Since they were apart I got them tinted. Now they look good and don't rattle. As for your leak you need to fix the roof leak first but when you take them apart you will see a silicone bead at the lower part of the middle metal bar. This might need to be renew!!
Post #163276 20th Aug 2012 4:28pm
excossack
Right back to leaking windows......
Over the weekend I ran some Sikaflex around the outside of the sliding windows where the frame meets the body in the hope of fixing the leak....But no.
The water can be seen dripping from between the raised section of metal and the metal that forms the frame of the window as shown in the picture.
So....Ideas on sealing this section of body?
I was wondering if the water is getting past the roof and body seal?
Ideas people please, I am getting fed up with wet carpets 1999 Defender TD5 110
Regards
John M0VAZ
Post #172236 30th Sep 2012 9:44pm
hi Retro
do you know anyone selling the single side glass as a kit or will it be bespoke ?
Post #172301 1st Oct 2012 7:27am
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Hi. It is an old thread but I see that you are still active.
Were you able to fix the leak?
Thanks.
Post #857438 22nd Sep 2020 3:51pm
