Home > Maintenance & Modifications > Broader wheels, broader mud guard sizes for a XS
BigWheels
I've fitted Terrafirma wheel spacers for better turning circle & now my 255 85s stick out slightly from the side of my wheel arches. The body , widows, handles & passengers looking out get mud coated.
I'm moving the front mud flaps forward & using rear (= wider) flaps at the front. Because my XS has colour co-ordinated arches, I don't want to replace them with the wider black after market ones. Does anyone here know of any other product that would help?
How much difference would taking off the spacers make to turning & handling, they went on when I put the bigger wheels on, so have never tried without... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #161543 12th Aug 2012 11:58pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
I fabricated a small section of plate that prevents the fling up. I'll post a pic tomorrow.
Alex 110 Tdci Double Cab
Post #161544 13th Aug 2012 12:12am
BigWheels
Thanks, much appreciated. Thumbs Up Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #161545 13th Aug 2012 12:28am
K9F
Entreq does extended mud flap brackets. I had exactly the same issue and they cured it. Thumbs Up
http://www.defender2.net/forum/topic5108.html?highlight=entreq If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161556 13th Aug 2012 8:43am
Glynparry25
Any pictures of how far your tires extend out of your arches?
What wheels do you have on and what offset do they have (or are they LR wheels with wider tires?
You are legaly allowed to have the tires stick out a little. It is the tread pattern that matters the most. My BFGs stick out a little but the tread is in-lin/ just inside the arches.
As above for mud-flap ideas Thumbs Up
Glyn Dog Sheep
Post #161558 13th Aug 2012 8:50am
ay4alex
Post #161839 14th Aug 2012 1:12pm
leeds
Dropping a vertical line from the wheel arch/flare the tread of the tyre must be inside that line. The side wall of the tyre can be outside of that line.
We stock the Entreq Mud flap extension brackets. XS Pete has done a decent write up here here Thumbs Up
Brendan
Post #161860 14th Aug 2012 2:13pm
K9F
leeds wrote:
Dropping a vertical line from the wheel arch/flare the tread of the tyre must be inside that line. The side wall of the tyre can be outside of that line. Brendan
It can be a 'grey area' as the arches are 'wasted' and whilst you may not fall foul of the rule above at the 12 o' clock arch position the tryres protrude further and further round the arch you go. Anyone got the definitive answer? Not had any issues myself MOT time but think it may depend on the tester's interpretation. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161895 14th Aug 2012 4:32pm
Green Machine
IIRC Fekete has some neat eyebrow extensions on his, so you retain the original body-coloured eyebrow and then add a small extension piece to its outside edge. I certainly remember seeing some on here somewhere, and think it was Fekete's 90. Don't know if he sourced them somewhere or made his own. May be worth a PM. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #161896 14th Aug 2012 4:33pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
The ones i used was the pacer fender flares...i got mine from Canada but you can get them on line in different sizes here are the ones i have
http://www.amazon.com/Pacer-Performance-52...sbs_auto_5
Here you go on how to fit Thumbs Up
http://www.defender2.net/forum/topic5309.html?highlight=pacer NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #161899 14th Aug 2012 4:41pm
Green Machine
There you go! Memory served on that one! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #161901 14th Aug 2012 4:46pm
