![]() | Home > Maintenance & Modifications > Sound deadening for defender 90 |
Yorkshire90 Member Since: 22 Sep 2011 Location: Yorkshire Posts: 205 ![]() ![]() |
You can do me a deal on your truck ![]() ![]() Although I've seen the Dynamat in a few Mobile Center 'audio pimped' trucks, I didn't know.you were distributors. Old man bought me bought me (birthday present) 2 packs of silent coat 2mm bulk pack and one pack of 4mm extra bulk for footwells etc. £158 delivered. Although it lacks the finesse of.the dynamat (some goo around the edges), it's actually much better than I anticipated. Will see how much it covers. Only put a couple of strips on as a quick tester but should do the job nicely. Amazing "knock knock" panel test difference. Tbh, I don't mind the noise as it is and my amazing 2 speaker standard stereo isn't going to get your sound system worried anytime this millennia ![]() SOLD Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-forever (most likely!) Daily drives: Mercedes E250cdi E Class estate, Modified Skoda Yeti, 05 Honda Jazz for those short runs! http://www.defender2.net/forum/topic11056.html |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Truck is for sale
![]() Once you get it fitted your two speaker system will be like a four speaker system anyway ![]() Last edited by mobilecentre on 18th Jul 2012 11:59am. Edited 1 time in total |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Apart from NoiseKiller, Exmoor Trim now sell sound deadening matting (probably expensive though).
I only want it to for the driver's cockpit & front passenger, so engine & transmission noise stifling. Would double thinner matting be more effective than a single thicker layer? Lastly, NoiseKiller's blanket has lead in it http://www.noisekiller.co.uk/acoustic_blankets_products.asp#NK006 . This cause me some concern as lead oxide may eventually escape through the other fabrics/if damaged & be sucked into the vehicle & inhaled. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
I have just insulated mine using the insides on one of these kits http://www.ebay.co.uk/itm/MILITARY-LAND-RO...438wt_1273
Basically they are the same closed cell foam as the noise killer without the sticky stuff on, I just used spray glue to fix it where needed and a some aluminium foil tape to tape the seams in all it cost me about £20 and a 1/2 a days work I don't know the effects yet but will find out soon. I have used 75% of one kit so have some left I will be removing the doors and roof soon to insulate I think I will use about two kits so a whole truck including roof and doors for about £40.00 ![]() By jasong4110 at 2012-08-02 ![]() By jasong4110 at 2012-08-12 Jason. |
Very neat idea
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
you want to use wrightoffroad product it really is good only sold through exmoor trim but i know the guy that owns the main company and it works really well all the milatary vehichles have them fitted 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
