![]() | Home > Puma (Tdci) > 110 boot liner advice......please |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
i don't think there is specific boot liner to fit the rear tub.
i bought the exmoor trim boot liner thinking it was puma specific and ended up having to cut it and use self adhesive velco to keep it partially in place. it does look diy |
| Delskinz Member Since: 18 May 2012 Location: North Devon Posts: 84
Hmmmm....I have three working gun dogs and the 110 needs something as water proof as possible and easily cleanable for 6 six months of the year it contains water, mud, fur and feathers.
Anyone have any other suggestions? |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
I made one, but then noticed that any dampness that gets under it remains under the carpet so I took it out and just wash the carpet occasionally when it get's too grubby.
I put dirty mountain bikes in and the carpet still looks new when it's cleaned. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231
I got one posted from Nakantenga and it fits great!
http://nakatanenga-tours.de/shop/article_K...110TD4B%26 |
Marius - it looks like this doesn't go over the wheel arches just sits flat on the floor section, am I right?
I don't have the two exrta seats in the boot and need something that covers the whole of the floor. |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Same here except mine is used to cart muddy, hairy, feathery, hay, straw type stuff all year. But as has been said there is no Puma specific tailored solution that will cover the wheel arches. I've used off the shelf rubber mats that include the wheelarches in my pre Puma Defenders, 90 / 110 & Series but my Pumas just have the OE rubber floor mats laid over the carpets with the carpet over the arches left exposed. Yes the exposed carpet does get plastered but 30 mins with a decent vacuum and a wipe over with a damp cloth every few months soon sorts it. Over the years I found containing the dogs in an enclosed Lintran or similar box doesn't really cut down on the amount of potential mess and also limits what else you can carry at the same time. My Defender is in use in the countryside every day and I can live with mucky wheelarch carpets in the back but an alternative is to line them with the thinner stable matting or similar. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| sewin elwy Member Since: 08 Aug 2012 Location: Snowdonia Posts: 39
Hi Delskinz, Yep it was a problem that I had to! There isn't one made for the puma. I bought the Td5 option that the G4 LR ones used and I think it is for the 90. You have to fit it into the base first and then trim to fit, I have removed my rear seats as I don't use them so perhaps this makes it an easier option for me. your right about the shaped wheel arches/boxes they present a problem. What i did was to buy some closed cell high desity foam, can't remember the thickness, yes I can just checked for you! 40mm, took the angle from the vehicle and clamped it between two pieces of wood on the bench,one narrower than the other and ran the carving knife along the length replicating the angle on the wheel box. They fit a treat and are held in place with double sided carpet tape. The liner then fits perfectly apart from the fuel filler box at the rear right, you have to enlarge as the ninty is in a different place. One more really good piece of info! Someone now makes purpose made fitments to square of the puma wheel boxes they were in the new stuff section of LRO and cost about £95.00 if memory serves me right but I can't remember who or where to order from-----wait and someone here will! Hope this helps, martin. |
| All times are GMT |
