Home > Tdi > Think I need a new radiator!
WarPig
Im loosing coolant and on inspection my radiator is wet through when looking at it through the radiator grill.
So, assuming I need a new radiator, what are my options? A quick look at Rimmer Bros shows...
Genuine radiator £462
Genuine radiator & intercooler £544
Aftermarket version (probably Britpart!!) are about half price.
Should I go genuine, or aftermarket (buy cheap, buy twice!)?
Should I bite the bullet and get a modified intercooler from somewhere like Bell Auto Services?
What would you do?
Post #161404 12th Aug 2012 10:02am
K9F
Is the leak that bad? I had a bad one in a previous vehicle in my heater matrix which I cured with Radweld. This may be a cure perhaps....
If it were me....(obviously it's not) but my personal choice I would opt for an OEM radiator and combine it up with an Allisport intercooler. BAS or Alive would be my first ports of call. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161406 12th Aug 2012 10:15am
Depends what you've got around you, but there are companies out there that will re-core radiators for a lot less than a new one. Darren
Post #161408 12th Aug 2012 10:30am
wslr
The aftermarket ones are fine. Before you order one though, ring around a few places and see what Allmakes and Bearmach are offering before looking at Britpart. Then ask the person on the phone if there has been any recent issues with them as there may be a bad batch in circulation.
Post #161409 12th Aug 2012 10:39am
WarPig
what exactly is re-coring. Ive noticed lots of the very fine fins (dont know what they are called) are damaged/missing.
Post #161419 12th Aug 2012 11:36am
Essentially, replacing everything between the top and bottom tanks. You can even have them re-cored with a denser matrix to improve cooling for hot running engines. Darren
Post #161423 12th Aug 2012 1:32pm
buy cheap - buy twice
if you can spare the time, get it recored
I put a new OEM one in my 300tdi earlier this year, as I expected, no problems
There's also an oil pipe that needs to be replaced at the same time I seem to remember
Post #161433 12th Aug 2012 4:17pm
walfy
I had my 300 tdi rad recored in Bristol at the end of last year. Had a bigger core fitted. Total was about £160. So definitely shop around 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #161436 12th Aug 2012 4:44pm
spudfan
Ireland
Fitted a Britpart radiator to the 200 tdi some years ago and it is not a 100% straight forward fit. Was unable to use the original rubber washers that fit beneath it as then it sat too high. After a lot of messing around I finally used the rubber washers that come with the airfilters for the 200 tdi and got a tolerable fit. Luckily I was in an independents yard at the time so I had access to a lot of discarded airfilter washers! Next radiator I fit will be genuine! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #161441 12th Aug 2012 5:32pm
shaggydog
Mine had same problem very recently.
I replaced mine with a brand new alloy core one of ebay for £78, comes with 2 year warranty.
I did need the thread converters for the oil pipes but that wasn’t too much drama.
Just lifted out old one, dropped in new one, purged air and off we went.
(I say it like it was a pleasurable job, it was raining hard and we had to get it done that day. But it was a very simple job. Take the time to clean your intercooler too, it is worth doing)
Did it before an overland around the alps and it came back splattered with bugs but otherwise good as new with no dramas.
Just an option.
Post #161490 12th Aug 2012 8:41pm
WarPig
Thanks for the replies Thumbs Up
The leak got quite bad and I was loosing lots of water so I had to take it into my local indie garage who put a Bripart radiator on Big Cry Not my first choice but I needed my landie later that day so I had no choice. They claim not to have had any problems with britpart radiators, time will tell.
I got my original one back so I can get it re-cored for future use. I just need to find somewhere local that can do this. Any ideas?
Cheers Thumbs Up
Post #161866 14th Aug 2012 2:41pm
Romadog
Just googled radiator repair in south yorkshire and the below came up
Champion Car Radiators
Cliff Street
Mexborough
01709 580 456
www.championcarradiators.co.uk/
Autokool Ltd
Network Centre
Midland Way, Barlborough, Chesterfield, Derbyshire
0845 226 9143
www.autokool.co.uk/
Premier Motors & Radiators Ltd
44 Kimberworth Rd
Rotherham
01709 555 507
South Yorkshire Radiators
Wath West Industrial Estate
Derwent Way, Wath upon Dearne, Rotherham
01709 878 908
RJM Plumbing and Heating Services Ltd
Google+ page
34 Campion Drive
Swinton
0800 458 1143
rjmplumbingandheating.co.uk/
Autorads 1983 ltd
298 Attercliffe Road
Sheffield
0114 273 1771
www.autorads.co.uk/
Power Flush 365
19 Hawthorne Street
Barnsley
07930 521462
Post #161885 14th Aug 2012 3:50pm
WarPig
Thanks Romadog Thumbs Up
Post #162112 15th Aug 2012 1:15pm
