![]() | Home > Maintenance & Modifications > Solar Battery Maintainer for Defender in Storage |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Last winter I didn't use my Defender for a few weeks, left it in the garage, and my battery went flat (left the interior light on
But - I have just managed to get another garage, but there's no power in this one to power the trickle-charger... My new garage:
...Yes I know I need to modify the door to get a Defender in... So I was thinking about buying a solar charger so I can keep the battery topped-up when the Defender's left in the garage for any period of time. The garage has a SW facing window (on other side, so can't see on photo), but also I could mount the panel on the roof if required... There's a few on ebay from very small costs, but I don't want to buy total junk just to find it's not man enough for the job... Anyone done this? I guess caravanners do this all the time? All advice gratefully revieved. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
No disrespect intended, but would you get enough quality sunlight that far north to make a solar charger effective.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Bloody cheek! It's sunny today |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
we have a ford focus on call car at work that goes weeks without use, it has a tracker so the battery goes flat after about 2 weeks, a brief case sized solar panel from Maplin that sits on the dash and plugs into the cigarette lighter has sorted it DEFENDER 90 TDCI XS,
Visited a hospital north of Edinburgh that had a number of internal, landscaped open courtyards. Unfortunately the grass kept dying as it didn't get enough quality sunlight. They replaced it with AstroTurf.
I'm sure a solar charger would work ok for most of the year, but you specifically mentioned winter, and I just wonder if the cheaper units would cope during the dark days.
Done more digging...Ring do a 2.4w one at "Ring Automotive 12v Solar Trickle Charger" (sold by Maplins Webdeals...)
http://www.amazon.co.uk/gp/product/B005ERHAX4/?tag=recharradio-21 They also do a 4.8w one... http://www.amazon.co.uk/gp/product/B003M9FWY0/?tag=recharradio-21 Looks pretty cheap - probably worth a punt... I'll do some more reasearch... Thanks for the ideas LR90 & Welshgas Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
LR90 - any ideas if this is a 2.4 or 4.8w item ??? 2.4's are pretty cheap, but the 4.8 is 3x the price... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Most solar chargers seem to be of the internal variety, sitting on car dash, but you plan on having your vehicle in the garage. Therefore an external marine grade panel might be better. Even wind power
http://www.force4.co.uk/c/69/Solar-Power---Wind--Chargers.html
unsure can check but wont be for a week DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6042
For a bit more umph - Maplins > http://www.maplin.co.uk/13w-solar-briefcase-99760 1999 Defender TD5 110
thats the one looks the same from memory DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Thanks, guys, I'll drop into Maplin next week.
Might be worth checking, on the car at work the battery was fitted in 08 due to the original constantly failing, this was when the solar charger was purchased no problem since at 4 years approx old, the description on Maplins site states it comes with a charge regulator but may be worth asking thier tech department DEFENDER 90 TDCI XS,
| quentin Member Since: 23 Jul 2012 Location: on tour Posts: 119
If you took notice of this bloke you'd be mounting a 100w panel on the roof of your Defender
(wouldn't bother with the airfoil part tho) I used to keep a 20w panel perm wired on the parcel shelf of my Fairlane because the battery would go flat after a week, the panel kept it good for another 3 years till I sold it, granted it was always parked outside. |
