![]() | Home > Td5 > 3 amigos appear and stereo cuts... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
You really need to find out what the fault recorded with the three amigos is to get a better idea of what's happening. The most common cause of the amigos is a faulty wheel speed sensor or faulty harness from the sensor to the ECU, but I have never heard of this having any effect on the stereo!
When you reset the lights, what error code(s) were recorded? |
oysbjerk Member Since: 15 Apr 2012 Location: Haugesund Posts: 3 ![]() ![]() ![]() |
I have not had the error codes read yet. If I turn off the ignition and restart the warning lights are off and back to normal.
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Sounds simmilar to what I had....... does it happen when going over bumps or uneven ground?
If so, check all the earth cables- Battery, Chassis (next to battery box and looks like a p-clip) and then on the transfer box. Regards, Glyn ![]() ![]() |
Good news.
Got the fault codes read....loss of power to ABS...and various other functions... Turned out that one of the screws on the 100A fuse link under the RH seat was loose ![]() ![]() ![]() Thanks for the help guys. ![]() |
![]() ![]() ![]() ![]() ![]() ![]() Glyn ![]() ![]() |
