Home > Puma (Tdci) > Coolant level
david110
Scotland 2015 Defender 130 Puma 2.2 HCPU Santorini Black
Coolant level
Has anyone had any issues with their coolant level in the puma TDCi 2.4, I have just noticed that my coolant is very low and the puma hasn't done 14,000 miles yet. It had its first service or 12,000 mile service back in December and only noticed the low coolant today and I could also smell coolant that's what drew my attention.
Post #159993 4th Aug 2012 11:28pm
wslr
Sounds like you may have a leak. Fortunately, the OAT coolant leaves a pink deposit when it leaks, so take a look around.
Post #160130 5th Aug 2012 5:16pm
rossy
Don't panic just yet David
There have been similar queries on this over the past year and it seems that most of the time its simply the filler/expansion tank cap thats the problem. If you unscrew it and find that the plastic threads are wet then its most certainly the culprit. Mine is similar - everytime I top it up it soon goes down again but seems to stop and settle at about 1cm below the 'full' indicator so a new cap will be fitted next service
Post #160136 5th Aug 2012 5:32pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Sounds exactly like mine.....
After numerous tests for headgasket leaks etc, etc the dealers put the header tank and cap on a pressure test and found that the cap valve opened at 1.19bar where it should only open at 1.4 bar. New cap and all is normal now........
BTW, there is an alarming amount of blown headgaskets on these 2.4's so rather make sure and demand they do a proper pressure test as well as a coolant chemical analysis!!!!!!
Post #160266 6th Aug 2012 9:39am
david110
Coolant level
Thanks for the replies from everyone, Im going to phone the dealer and get the Puma checked over, especially the pressures on the header thank...
David
Post #160410 6th Aug 2012 10:07pm
astoltz
South Africa
Today I bought new cap at dealers and installed it. Will see if there is a difference on my 2.4
Abrie 1997 Land Rover Defender 110 HT 2.8i
(BMW M52)
2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
Post #160669 8th Aug 2012 12:04am
landybehr
Hi there,
what can be best done to monitor the coolant level in the expansion reservoir ?
A low-level warning is quite useful I think
There is one solution where a bleeding cap is replaced. I have read about concern that it might only give alarm when the water pump is low on water - which may be rather late.
Does anybody know about a different cap for the expansion tank with a sensor in it - as for the RRC with plastic expansion tank ?
This is a nice DIY-idea: http://www.mdocuk.co.uk/forums/viewtopic.php?t=38102
I wonder if this could work and be worthe the effort ?
(sorry for the small pic, donīt know what went wrong)
(basically it is a connection between the pipe at the bottom of the tank and the bleeding pipe which is above coolant level. The coolant level in that connection will have the same level as the tank and could carry a sensor)
Post #243072 12th Jun 2013 9:29pm
I had a similar problem a year or two back. Turned out that the cap needed replacing, but the new cap and increased pressure then caused the water pump shaft seal to start weeping, so new pump fitted. Been ok since.
To check the level I dip the header with a pencil because I can't see the level in the "translucent" tank unless I backlight with a torch.
Post #243105 12th Jun 2013 10:47pm
landybehr
My problem has been that the big coolant hose that comes from the back of the water pump and goes to somewhere to the block was punctured by a jubilee clip. Common problem. The dealers have that hose in stock. (Itīs a 2.2).
The leak gradually got worse but I didnīt notice, because the car was half a year old and, ok, I didnīt check it due to the youth. She drove absolutly faultless. No overheating, no power loss, heating was ok although a bit weak for what all say about the Pumaīs heating power. But I came from SIII/RRC so what do I know.
When I noticed there was about 1litre missing. If topped up, it would immediately loose it again. As I never witnessed puddles under the car before, the leak must have been there for a longer time. It was March and I remember those times were pretty cold. That could have masked a reduced cooling capability.
Anyways, that is my story Smile And I am keen after an low-level alarm. Just checking at the gas station is not enough.
Post #243224 13th Jun 2013 1:38pm
