![]() | Home > Puma (Tdci) > Leak from gearbox? |
An oil leak on a Land Rover? Yes, I've seen one or two of those before
![]() If I'm reading your pictures correctly, it looks like the rear output seal on the transfer box. Not wholly uncommon but also not too difficult to fix either. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
It,s just Land Rovers way of letting you know it,s not empty yet. 2005 Td5 90 XS
Steve |
If a land rover leak oil means there is oil inside.......
serious mode ON there is a recall (P022 thanks to rasmussen) for te oil leak from the rear shaft (oil on brake drum) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 8th Aug 2012 12:59pm. Edited 2 times in total |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Thanks guys - I figured I was asking for it by posting a query re. oil leaks and Defenders!
![]() Is there any way to check if a particular vehicle has had the requisite recalls carried out? Would vehicles that are out-of-warranty be covered? I'm curious if the fact that I'm parking on a rather steep incline for the past two months has anything to do with this? |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Register on Topix (it's free) http://topix.landrover.jlrext.com/topix/vehicle/lookupForm , and enter your VIN number. Will tell you if there are any outstanding recalls.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46 ![]() ![]() |
Sorry to intervene, I have registered on Topix and when I type in my car's vin I can see: Outstanding Campaigns: P022 - PARK BRAKE OIL CONTAMINATION This means that the seal has not been change by Land rover dealer so far? Can I also read from this that clutch issue has been solved earlier on my particular car? I have only had the car for less than 4 month and I don’t know if the clutch has been changed or not? Cheers, |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
Great recommendation - mine says the recall to fit the 3.2TDCi has not yet been completed under warranty? 1951 80" S1 2.0
Hi Rasmussen, As far as I am aware there was no product recall regarding the clutch, as not everyone had this problem. The P022 recall should be carried out by you local dealer even if your vehicle is out of warranty.
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
I am sure this is a full safety recall and that LR will do this FOC even outside of warranty period
