![]() | Home > Maintenance & Modifications > muffler removing on the 110 puma engine |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 ![]() ![]() ![]() |
For the benefit of the holders of Def> 2007 Ford engine, add the impressions gained from the removal of central muffler:
- A slight increase in torque at low revs, though noticeable, such as exit from the roundabout at third you feel a little less than that effect of vibration due to a poor copy. - A slight increase in diamond output from the tube end, especially at the very least, personally I do not mind, we say that makes a noise more "masculine", and a slight whistle of the turbo, before the change in dry marcia.Niente issue of striking, and nothing in comparison to a Td5 adopting the same treatment (unfortunately .. ![]() ![]() I note that my 110 has already undergone the change of the sensor clutch. To get a more favorable angle postriore I also eliminated the barrel end of the muffler, so being able to bend the curve and to shorten the tube, resolder the "lips" final. ![]() 110 Td4 MY07 "E" Keswick Green |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
And mine
![]() ![]() Click image to enlarge |
But you're already ahead!
![]() Surely the next job will do the same thing! ![]() 110 Td4 MY07 "E" Keswick Green |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Doesn't it fail it's MOT like that?? Been considering this on the 300... Ben
Rebuilt 1996 black/white Defender 90 300 TDi |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
MOT is only a noise requirement, something like it doesnt make excessive noise or similar. my 90 tgv has no silencers and passes no problems. Cheers
Cedwat Member Since: 18 Jan 2010 Location: North Posts: 22 ![]() ![]() ![]() |
Hi,
I have a 110 puma too and am tempted to change the exhaust too. I think I have to keep the catalyser system as I may not pass our "contrôle technique" here in France! I have seen that many company in the UK propose "performance exhaust" for the TD4 : TD5 alive, JE, twisted, etc all have their "system". What is not clear to me is the difference between them. To be direct : it is just a tube, isn't it? Or is there secret science here? |
They are all just pipes
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
i have a full stainless steel system from janspeed on mine side exit aswell with only a resinator sounds the nuts #
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
Yes this would fail the MOT, not on the noise but because the exhaust must extend clear of the bodywork/chassis. The back box on my V8 Disco was missing when I bought it.... made a luvvverly noise but not paticularly loud. However i had to add an extension to make it stick out the back to pass the MOT MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
Andrew, did you leave the Cat in place or did you remove that as well? |
Removed the cat. Got the de-cat pipe from Pete Bell
