![]() | Home > Puma (Tdci) > Tire/MPG Question |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
a few mpg i would suggest. Mike
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
I'm about to do the same on my 110 (Td5), mainly as i use it for a "car" quite often, and don't want to wear the MT's out too quickly, plus it's amazing how noisy BFG MT's are (And how quiet the grabbers are too)
I'll let you know my findings. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
my MPG did not change when I put the BFG MT. They are bit noisier than the OE General TR but nothing compared with Pirelli Sc MT. Puma 110" SW
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I'd imagine that the size of tyre would have more to do with it. I switched from Grabbers to BFG ATs both 235/85R16 and noticed no change in mpg. I bet if you swap from fat MTs to Grabbers you might notice some change but I don't imagine it would be wapping if they were just 265s.
That`s true. Im running 285`s so the engine runs at lower revs Puma 110" SW
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Same here, and same result. the difference between Road/AT and MT is soo minimal nowerdays- unless you go for something 'EXTREME' Glyn |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 ![]() ![]() ![]() |
Just put on some Cooper STT muds yesterday - have driven 400kms already (country and city). Fantastic tyre, definitely more stable on cornering (compared to the 235/85 Grabbers) in the city and softer over bumps. Minimal hum at highway speeds. Very happy! 1998 RR HSE
2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
scatt Member Since: 24 Aug 2009 Location: nottingham Posts: 103 ![]() ![]() ![]() |
ive ran with cooper stt's for the past 18 months and never had a problem even when used hard offroad, I have just changed from 33x12.50x15 to 35x12.50 and im getting approx 30 mpg on a run.
