![]() | Home > Technical > Puma "Airbrakes".... |
At least in Italy there is no problem or dubt about the mudflap!!! they are mandatory by law!!!
also who is behind my car is thanking me (his/her front glass) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I believe my front mudflaps protect my own underside - it would seem weird to have the front and not the back. Plus - even though lorries and SUV drivers spray crap all over me, I like to think I'm better than them
![]() But shout it at them in German because life is also terrifying and confusing... |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2496 ![]() ![]() ![]() |
I guess on a 90 the design is OK, but not on a 110. I removed mine as they were twisted and did not put them back again. Can a 90-type be fitted straight to a 110? or is there an issue with the tail pipe? Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I have now processed my fuel figures and can confirm......
... that removing my rear mudflaps has made absolutely no discernable difference at all to my fuel consumption. My vehicle is a 2007 Puma 2007 DC with IW canopy, 285/75 KM2s, usually running laden. Average consumption over the last two years (42000 miles) is 25.46mpg. The best I have ever achieved between fills is 29.28mpg, the worst 21.17mpg. For the last 8 months it has had a Patriot rack (with rails) fitted, which perhaps surprisingly hasn't made a discernable difference either. I guess that the aerodynamics are so bad anyway that a rack doesn't make an appreciable difference. In two years that amounts to 1,652.56 gallons (7,580.54 litres) at a cost of £10,168.54 ![]() PS - If I do ever replace the rear flaps then they will be fitted to the rear crossmember, where they will be more secure, will work just as well, and it won't be possible to reverse over them and rip them off. |
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Yup, and even better result can be obtained if you massage Sikaflex into your entire body and wax...... ... the outside of the truck! |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I agree, they aint bought for economy, but none of my cars have ever been particularly economical, my 90 is probably in the top three good ones!! Maybe I am wrong, and if I am, sorry for starting the thread, but the numbers here do add up to a saving.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I thought that was Zag's 110 for a minute there. Sorry ![]() |
Don't apologise, 10% fuel saving for removing two bits of rubber do indeed add up to a considerable saving. Maybe it should be me apologising for taking the mickey with the nosecone and aerial/underpant quip. But for me it has been an enlightening and entertaining thread. Sorry anyway. ![]() Treat every day as if it is your last....one day you will be right!! |
quentin Member Since: 23 Jul 2012 Location: on tour Posts: 119 ![]() ![]() ![]() |
What do you mean, you dont buy a fender for economy. granted its a moot point but ....
my Td5 is the most economical car ive ever had, as far as fuel constipation goes. The only one that came close was my 1.6 liter 80" but it only went 80kph flat out .... downhill. The Td5 almost gets better economy at 110 kph towing a caravan. As far as the removing the mudflaps for better economy.... problem I have with that is the two big solid chunks of rubber in front of them that disturbes the airflow. Meybe fitting some Mad fiber road clincher wheels, or Pitts Special wheel spats might convince me ![]() |
I took the keyring off (big metal one) 32.8 mpg now as 32.7 before,it all helps ya know Mal ![]() 1968 1/32 scale Britains 109 Pick up. |
Not carrying the wife and kids around improves fuel consumption and noise level
Letting all the air out of the tires, that is 2x 2.5 KG from each front tire, plus 3X 3.3 KG from each rear tire plus the spare, so I am getting a total weight reduction of 14.9 KG by doing just that
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Nice idea, I'm going to the Balloon shop tomorrow to get all my tires filled with helium. ..... Holy Smoke Batman I just did a google search for "Landrover Balloon' to try to find a cartoon of, well a ... Landrover Balloon to add to the post and I found this instead &feature=player_embedded#! What about the poor sod who parked his beloved D1 where some rocket scientest crash landed his space ship. talk about Freaky |
