Home > Puma (Tdci) > Rough at startup and smoke
d92qyh
Hello,
The last couple of mornings I have started my 2007 puma up and it has been rough with a fair bit of smoke for about 5 seconds after starting. After this it gets smooth as normal and the smoke stops.
Any ideas? I was thinking glow plugs or injectors.
Tried turning the ignition on twice this morning to let the glow plugs do their thing twice but still the same issue (although less cranking reqiured).
Post #122711 9th Feb 2012 5:19pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mines the same when it's cold.
Monday was the worst as I'd not used it all weekend and was covered in snow and ice. Gave it a couple of glow plug cycles but it fired up after three or four turns of the engine, sounded like a bag of spanners and chucked out a lot of smoke, but after 10 seconds or so it had settled down.
When it's warm or during the summer it's fine.
I'd be tempted to say its normal (mines recently been serviced too), but don't hold me to it.
Post #122851 9th Feb 2012 10:52pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Mine did that when my egr was making loads of noise, got the egr taken off and greased up, all is well now Smile 90 Puma HT
Post #122854 9th Feb 2012 11:02pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Mine was bad last week. Healthy battery, just turning over but wouldn't fire. Smokes a lot on start up and runs rough. Soon clears though.
Post #122918 10th Feb 2012 8:33am
Glynparry25
Have the EGR checked, mine did the same a few years ago.
Glyn Dog Sheep
Post #122999 10th Feb 2012 2:08pm
I have noticed that mine has been doing this too on the recent cold mornings, a few seconds of dense whitish smoke whcih clears in a few seconds, and even more rattly than normal.
As far as I can tell, the EGR is still working properly (at least it still makes the ugga-ugga-ugga on switch off).
Post #123019 10th Feb 2012 3:35pm
d92qyh
Thanks for all the replies. Still having the same issue (seems to be blueish smoke) on first startup with rough running but really no problems at all after 5 seconds.
Never seem to have any problems after the initial first start of the day as recently left it for 8/9 hours in the day after driving to work and no issues when starting in the evening.
Due for a service soon so will get it looked over.
Post #123422 12th Feb 2012 3:15pm
Naks
chuck in some 2SO and see if it makes a difference? It may just clean up some carboned-up components. --
Post #123582 13th Feb 2012 9:13am
StuLandy
2008 Defender 110 Puma 2.4 CSW Alpine White
Hi all, great site..some really usefull stuff on here...My Landy has just started to do this after filling up with Tesco's fuel. Back on the Asda stuff now but seems to be getting progressively worse..may not be fuel related but some pointers/ideas would be helpfull..
cheers
Post #158579 28th Jul 2012 11:23pm
Captain Speaking
2008 Defender 90 Puma 2.4 CSW Tonga Green
Sounds like the EGR...my D3 was just the same, and it was indeed the EGR.
Re Tesco fuel - don't do it!! I use Ultimate etc and it really does make a Difference.
Post #158732 29th Jul 2012 11:58pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I use Tesco Diesel + 2so and have done since new - No Problems , 2010 90 XS and now has 25,000m + on the clock. Only time I don't use Tesco is when I'm travelling when I use whatever is available. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #158807 30th Jul 2012 6:57pm
bob neville
Sounds like my TD5.
Only started after the EGR was blanked. After initial start everything is fine.
Changed the MAF, no oil in the harness, no apparent oil loss, no water problems Shocked
My Puma blows a bit of blue smoke in the winter on first start but that is just a little unburnt fuel.
TD5 is back in next week and the workshop are going to have a look to see if they can find the cause. In my case it may be down to something gummed up due to very little use, I am sure all will be revealed soon Thumbs Up
2013 Defender 90 CSW - sold
Post #158811 30th Jul 2012 7:17pm
ericvv
It sure does. I have been using cheaper French supermarket diesel for years, and the engine hammered away rather distinctly, and on turn off, the EGR cleaning "chuka chuka" was quite loud....
About 4 months ago I switched to using BP Ultimate, and immediately noticed a change in engine sound level, much smoother, less hammering. And the "chuka chuka" has become a nice quiet discreet cleaning cycle.
I have no idea about any change in fuel economy with BP Ultimate, but one thing is for sure, everything works like a dream now. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #158814 30th Jul 2012 7:44pm
StuLandy
Cheers for the replys lads, got back onto the Asda fuel, threw about 300ml of 2so in on a full tank and all is well, less smoke on start up and not lumpy. Seems a little quieter and the egr valve cleaning cycle is less prominent sound.
Would you always put 2SO in every fuel up or every other. Would you use 2so with bp ultimate (only when i'm flushed with funds will she get BP).
Post #159982 4th Aug 2012 10:51pm
ericvv
Post #160003 5th Aug 2012 4:52am
