![]() | Home > My Defender > My new project 90 2.2 arrives today for its new heart. |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Hehe, I hope it will be running next week, I had to order another but brand new this time engine and gearbox today as im still waiting for my original order from a different place to arrive
![]() Tomorrow I hope to have it arrive all brand new and sparkly ![]() Pete Last edited by bell-auto-services on 29th Jul 2012 8:26pm. Edited 2 times in total |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
well if thats the case pete you know where i am hint hint
![]() if its up for grabs steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Does or will the curves and length of the air intake pipe from the wing slow down the speed of the air entering the filter? 1999 Defender TD5 110
i doubt it mine is currently running through a pipe from the snorkel which will incur a ram type affect but i may be wrong
the other good thing about that filter is you dont have to modyfy the original filter box steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
that would looka lot better knocked up out of ali ![]() |
You know my past, diesel engine have no secrets for me ![]() ![]() ![]() If I could stay 1 week in the workshop with you I could give a lot to your work..... ![]() ![]() ![]() ![]() IID Pro MV License |
Or 1 week with the Denso Fomoco devopment unit........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
you wana get that chassis waxoiled as well pete before it starts rusting 2015 2.2 tdci hardtop xs
One Prize competition:
Why the inlet valves are bigger than exhust? A hint, do not think about pressure effects or pump effects, think about a "wall"...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
more air can be pushed in from the turbo plus the piston is pushing the gasses out
im probly so wrong lol steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Pete, will be interesting to measure the max air flow used by the 3.2...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
And for a non turbo engine? It seems a logical answer but it is not correct .... Again ..... Pume engine head zoom in ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Inlets are generally bigger partly because the inlet charge pressure going into the cylinder is lower than the exhaust outlet pressure, though many combinations of valve size ratio are used from manafacturer to manafacturer.
It also gives the engine manafacturer more choice of valve seat design that they may require depending on application and the valve size chosen. |
I hope to measure it unrestricted somehow, not worked out how exactley yet though lol. I may do some vac pressure tests on the current inlet setup and see if i can make it as free as possibile. |
