Home > Maintenance & Modifications > hand brake adjustment
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Hi all.
About 3 weeks back my hand brake warning lights started staying on because the lever was not seating properly. I took it apart and found the inner cable was pushing the lever up. I adjusted the drum as per the wners book and also adjusted the outer cable so the lever sat down. Now it is doing it again, is there another issue of which I'm getting these symptoms that I need to find or is more adjustment needed?
Cheers.
300tdi 90. Rhubarb and custard let fly with their secret weapon.
Post #157595 24th Jul 2012 5:48am
Sometimes it's the rubber gaiter that's around the lever.... my old 300 used to do that. Can't remember how I cured it, think it was remove the rubber, heat it in the kettle or a hot pan, and then re-shape it so it was more elongated as opposed to being angled, so it didn't try to "lift" the handbrake lever itself.
Post #157604 24th Jul 2012 7:20am
lambert.the.farmer
Thought of that so took it off, still no better. Rhubarb and custard let fly with their secret weapon.
Post #157659 24th Jul 2012 11:38am
