Home > Maintenance & Modifications > Bolt holes.
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Bolt holes.
I have (or will have on Tuesday) a 2008 Defender with hinged lamp grilles and a rear ladder bolted on. I want to remove them and fill the drilled holes. What is the best way to do this?
Post #157211 21st Jul 2012 7:13pm
ZeDefender
Well, apart from 2-part filler used on any car, the good thing about Defenders is that there are rivets everywhere. I've just added a few to the holes here and there where things have been taken off - you can sometimes buy them in body colour too Wink Tell someone you love them today because life is short.
Post #157216 21st Jul 2012 7:41pm
Thud
I suppose an extra rivet here and there will blend in just fine. LR do an alternative grill, 'front light pack' and 'moulding kit'. I wonder if it would cover the holes?
Post #157217 21st Jul 2012 7:46pm
Killer90
Site Sponsor
rivets will be the best thing to put in there but later on you could have them filled and the panel sprayed wouldnt be to expensive to have done Thumbs Up
Post #157220 21st Jul 2012 7:54pm
Thud
Thanks for the advice chaps.
Post #157279 22nd Jul 2012 10:17am
leeds
Ladder bolts are likely to be 8mm so probably 8.5 mm hole, that is a large pop rivet!
Choices include filler ( err no!) blanking grommet, with or without a dab of silicone, bolt, bolt head sprayed same colour as body, bolt with plastic dome cap on, button head bolt.
Brendan
Post #157280 22nd Jul 2012 10:24am
ZeDefender
Very true Thumbs Up Also, filler would not be my first, second etc. choice either.
I meant rivets/rivnuts. M6 rivnuts have a hole size of 8.5 - 9mm and you can buy them closed-ended so they won't leak. They would look tidy (as if they had a purpose) and would be easy to drill out later if you changed your mind.
I think the panels are aluminium there so ally bolts/rivets/rivnuts would be safest...
p.s. As Brendan says, a dab of sealant is a good idea before putting a grommet, rivet etc. in and if you can't get hold of a rivnut tool, JSG has designed an excellent device here: http://www.defender2.net/forum/topic8631.h...ivnut+tool
Matt Tell someone you love them today because life is short.
Post #157287 22nd Jul 2012 11:20am
