Home > Maintenance & Modifications > After market DRLs
Page 2 of 2 <12
Yorkshire90
boode wrote:
Excellent product and very good service from Tim.
Seconded. Excellent product. If I can get these kids reports finished off I'll be adding a review with plenty of day and night pictures. The DRL side lights are bright enough for use as headlights Mr. Green "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much*
IRB Developments rebuild: Project Ice cube 2012-......
http://www.defender2.net/forum/topic11056.html
Post #155750 15th Jul 2012 5:20pm
mobilecentre
Voltage sensing relays start at £10
http://www.mobilecentre.co.uk/index.php?ma...cts_id=536
You input a permanent live and it will then switch the output live on only when the engine is running, this can be used on the DRL to simplify the process and enable connection underbonnet.
I would not advise using the alternator trigger wire, and the output is of course permanently live as it is connected to the battery. Our DRL kits uses less than than 1A of power to drive both lamps.
Post #155857 16th Jul 2012 10:04am
Tazz
Thanks for all the replies.
Looks like I may need to start saving if I want to go the whole way and switch completely to LEDs. You've given me plenty to think about in the meantime.
Post #156878 20th Jul 2012 12:31am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You could use a changeover (5 pin) relay as a simple way to kill the lights when you turn the sidelights on. The extra contact provides a "normally closed" circuit that is connected when the relay isn't activated. Configure it so that it is activated by the sidelight circuit and the normally closed circuit goes open.
Post #156881 20th Jul 2012 1:18am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi, I'm not an electrical guru but I if you use a 5 pin switch relay you would wire the feed from the side lights to pin 87a????
Any advice much appreciated. :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #156887 20th Jul 2012 6:21am
LR90XS2011
Halfords do RING LED DRL kits with everything in them for you to get the Killer or Alive DRL Bumper look, alternatively you could fit MINI head lamps that have a side light in them and swap the bulbs in the Land Rover side lights to LEDs and do the associated wiring changes either way it wont cost more than £100 probably much less if you are good with wiring DEFENDER 90 TDCI XS,
Post #156899 20th Jul 2012 7:43am
If you have a Puma and need an "engine running" signal, there is one available from the connector on the instrument cluster. It's normal use is for the heated windscreen circuit - the heated screen is only powered if the engine is running. Details are available on at least one of the heated screen threads on this forum.
Post #156903 20th Jul 2012 9:07am
mobilecentre
Our kit comes with a pre made loom that will plug into any Defender after 1996 and requires a single connection to an igntion live. All the rest is done automatically and as they replace existing lights no hole drilling / bumper cutting is required.
We have changed our bumper fabricator recently and have got a batch of different bumpers coming in with "various" options including our DRL version so watch this space!
Post #156909 20th Jul 2012 9:35am
WelshGas
Sorted. Thanks for the info about the 5 pin relay. Already had an ignition powered relay that supplied power to a unit with 3 cigarette type sockets for the sat nav and phone which also powered the DRL's . So I've used the output from that to provide the power input to the 5 pin relay and hence DLR's and then a feed from the side lights which switches that relay off when they are switched on which breaks the DRL circuit. Thanks for the tip. Totally legal now.Bow down LANDYWATCH
Post #157048 20th Jul 2012 7:45pm
Page 2 of 2 <12
