![]() | Home > Td5 > auto td5 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Have a word with Dan on Devon 4x4
Yella 90 or something like that is his 'handle'! QRZ M8VPF |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Jeremy on here has a td5 auto g4 bad boy!
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Yup, love it!
PM received and replied
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
Chris , read last months LRM and the Manx article...
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Which copy is that ADE
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I fitted one to Pam's 90 and had some involvement in the development of the Compushift system for the ZF.
Personally I think the Compushift option is a good one, not because of the Compushift itself, which does the job but has some limitations, but simply because you can tune the electronic ZF boxes to match the power output of the engine and your driving style. I have driven a conversion that wasn't very well dialled in and had the wrong torque convertor and that didn't drive very well at all so it really is down to setting it up properly. The downside of a hydraulic system is that you're pretty much stuck with the shift pattern you've got - at least with an electronic one you can change it quite dramatically. It's taken some time to fine tune since fitting it at the beginning of the year but it's almost there now with the shift points pretty much dialled in in all throttle and speed positions. I have a "map" written out now which works a lot better than the default map and I'm pretty pleased with it. I'm due to help fit another one soon and will be able to enter my map straight in as a starting point. I can always keep tweaking it though ![]() I've toyed with the idea of building a Megashift to control the ZF but not done yet as it's Pam's daily drive. It should be possible though and would reduce the cost of a conversion quite dramatically... |
, the one with the black G4 90 we had down unit.....with a bit of magic it flies along... Putting Dreams on Drives at JLR Solihull.. |
You mean VADER isle of man jobby
yep, thats our boy.... Putting Dreams on Drives at JLR Solihull..
Mega shift a 6 speed tdv6 box Dave? |
It should be possible if the tech details are available somewhere, MegaShift software can control up to 8 forward speeds so it's technically capable of doing it. The HP24 technical details are available as I have the technical manual for it but no idea if the 6HP28 details are available. It takes a lot of technical detail to do the job properly although some/all of that could potentially be reverse engineered from a working box in a vehicle. If someone wants to supply me with a box and test vehicle I'm up for a challenge ![]() |
Yes, our TD5 TR 110 had compushift. Worked well but I don't think it was set up to it's best. We sold it before I could find time to look at it. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
well all these high HP motors going in defenders and were still on manual boxes ![]() i see on the MSQ forum some of the guys are playing 7 speed lexus box |
