Home > Technical > Electric window
Page 1 of 5 12345>
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Electric window
Right guys....drivers side electric window has stopped working...passenger side works fine....
are they fused separately ? or is there something else that could have caused it ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #156732 19th Jul 2012 3:03pm
K9F
Right Karlos,
Fuse 15.... 5amps is the supply fuse to BOTH front windows.....
This supply is fed through two independant fuses for the front windows FUSE 34....20 amp for the driver's side...
FUSE 35....20 amp for the passenger's....
Each fuse supply then goes through their respective up/down selector switches to the motors....
Check the fuses first, if no go swap the switches over to see if the fault transfers.
If still no go would suspect an open circuit in the door umbillical (coloured wires red, blue and black (earth)) but you would need a multimeter to confirm the latter.
*EDIT* Again....There are other fuses in the system but as it is only happening on one side these can be discounted at this stage.
Good luck Buddy.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #156735 19th Jul 2012 3:14pm
Once again astounding electrical advice from Mal. Thumbs Up I wouldn't mind betting it's a switch but we'll see. I have never taken the door card off so never seen the set up behind there? Would be interesting to see. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #156737 19th Jul 2012 3:18pm
ZeDefender
Why would a 5 Amp fuse feed to 20 Amp ones? Tell someone you love them today because life is short.
Post #156738 19th Jul 2012 3:22pm
K9F
Kona,
Easy to take the door card off...Not so easy getting the inner plastic sheet off in one piece as they use a bead of the stickiest, gooiest Censored I've ever come acroos to stick it. Like black chewing gum it is.
Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #156739 19th Jul 2012 3:28pm
Removed, missed my moment !!!!
Post #156740 19th Jul 2012 3:28pm
K9F
Trying to keep it simple. Supply relay fuse...same set up you should have if you fit auxilliary lights. Thumbs Up
Ignition supplies relay 5 amp fuse, pulls in relay, contacts of relay supply through 20 amp fuses window motors. Thumbs Up
In this case 3 amp feeds 20/25 amp...
Post #156741 19th Jul 2012 3:29pm
I know the stuff you mean Mal probably great for holding the water in too if any works it's way in there Rolling Eyes WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #156742 19th Jul 2012 3:30pm
fekete
K9F wrote:
Right Karlos,
Nice one Mal, will have a look 2moz Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #156751 19th Jul 2012 4:01pm
spudfan
Ireland
Talking to someone who drives a VW van. He said that if it rains and he has a window down he is unable to get the window to go up again. This is due to where the switch is placed on the trim. If it gets wet at all the connections are knackeded. He had to remove the switch one evening and dry it with a hairdryer then refit it to get the window to go up. Seems that replacement switches are a big part of the warranty work.This came to light when we found out that our next lot of vans at work will be VW. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #156769 19th Jul 2012 5:12pm
Happyoldgit
I've got some pics somewhere and will attempt to find them but believe me the inside of the door isn't very exciting...
.....of course it depends on what sort of thing turns you on Rolling with laughter Steve.
http://forums.lr4x4.com
Post #156784 19th Jul 2012 6:46pm
K9F
Karlos,
Any update? Hope it turned out to be something simple.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157004 20th Jul 2012 5:28pm
fekete
Mal, just checked the 2 fuses that are together and both ok will look for the 5 amp 2moz mate...its getting hot in there without aircon and only 1 window... can't even smoke Big Cry NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157023 20th Jul 2012 6:42pm
fekete wrote:
Can't even smoke Big Cry
I feel so sorry for you Twisted Evil Rolling with laughter WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #157028 20th Jul 2012 6:48pm
K9F
Karlos,
The 5 amp one is ok if the other window is working.
Swap the switches over next.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157030 20th Jul 2012 6:51pm
Page 1 of 5 12345>
