Home > Group Buys > Anti Theft Bonnet Hinges - Group Buy!
Sign Up
(35)
User Registered Confirmed
farmer giles23rd May 2012 10:56am
lrmaniac23rd May 2012 11:25am
defender423rd May 2012 11:56am
JSG23rd May 2012 12:06pm
Zagato23rd May 2012 12:20pm
Inigo23rd May 2012 12:37pm
sparkylee23rd May 2012 1:17pm
Glynparry2523rd May 2012 1:34pm
kmac23rd May 2012 4:04pm
LR90XS201123rd May 2012 7:05pm
SGH23rd May 2012 8:40pm
bob neville23rd May 2012 8:47pm
roamingman23rd May 2012 9:06pm
jav-uk24th May 2012 8:25am
pjh24th May 2012 10:22am
blackwolf24th May 2012 10:46am
daviec124th May 2012 3:23pm
ChrisP26th May 2012 1:13pm
szracer30th May 2012 9:48pm
MrFlips31st May 2012 12:55am
Rozzer1st Jun 2012 5:09pm
T1G UP1st Jun 2012 9:02pm
Harris11013th Jun 2012 11:07pm
dgardel17th Jun 2012 3:54pm
JOSNOS27th Apr 2013 11:02pm
Generaldej9th Jul 2013 12:16am
AndrewS15th Oct 2013 1:46pm
steve E15th Oct 2013 11:01pm
Jim_Bean16th Oct 2013 3:11pm
Lewisgregory828th Oct 2013 3:40pm
Tiger28th Oct 2013 3:44pm
Smilesapart30th Oct 2013 7:33pm
myonehere11th Nov 2013 12:01pm
kbf198111th Mar 2015 7:52pm
OldDD9th Dec 2016 12:17am
Page 8 of 13 <123 ... 789 ... 111213>
ZeDefender
It seems Zag is off the hook Thumbs Up
It's good news but I'm a bit stressed now as several of you "vultures" are already circling the kill Laughing
I'll figure out who asked for what and when and add you to the list fairly. Please be patient as I will send the hinges out in sensible order and only ask for payment for the last pairs when I've got it all straight Wink
Matt Tell someone you love them today because life is short.
Post #154951 11th Jul 2012 10:29am
ZeDefender
All of you who gave me your addresses, your hinges are on their way Thumbs Up
Does anyone know what's happened to LR90XS2011?
He's paid up but I can't seem to contact him. I need his address.
Is he on walkabout?
Incidentally, the same goes for daviec1, szracer and Harris110 - can't seem to reach you. Do you still want them? PM me in any event and don't worry if you've changed your mind - there are several other members interested Wink
Post #155406 13th Jul 2012 3:33pm
bob neville
Arrived this morning, excellent quality Thumbs Up
Thanks for sorting this out Matt.
2013 Defender 90 CSW - sold
Post #155514 14th Jul 2012 12:29pm
ZeDefender
Good - I was a bit worried about the crappy box (if you got that one) Laughing
All the others went out today in "posh" boxes Thumbs Up Tell someone you love them today because life is short.
Post #155534 14th Jul 2012 2:35pm
ZeDefender
Note:
The plastic bushings are very dense and a very snug fit in the hinges (as you can tell when first removing them when unpacking - although at least you know they do fit). Even though the outer faces are beveled to help with fitting, it's much easier doing both hinges at the same time so the bonnet is offered up square to both bushings in the bulkhead mounting (how I did mine). You have to be a little patient and I don't think it would work from an angle.
I did mine in 20 minutes or so but apparently that can't be guaranteed...
Hope that helps.
Post #155823 16th Jul 2012 7:18am
T1G UP
recieved...many thanks Thumbs Up
Post #155839 16th Jul 2012 8:59am
ChrisP
United Kingdom 2007 Defender 110 Puma 2.4 HT Belize Green
Collected this morning from Royal Mail sorting office-all arrived safely
Thanks from me for making the effort for a Group Buy, its appreciated
Cheers.... Thumbs Up
Chris
Post #155905 16th Jul 2012 2:27pm
Glynparry25
Matt,
Which address did you send mine to?..... Just so I know if I need to warn the folks off.
Cheers,
Glyn Dog Sheep
Post #155906 16th Jul 2012 2:35pm
ZeDefender
Glynparry25 wrote:
Matt,
Sorry - I sent it to your parents as the old boy in our local post office (more of a tobacconist) panicked when I asked about using DHL labels for BFPO addresses. Hope that's okay. Tell someone you love them today because life is short.
Post #155914 16th Jul 2012 2:56pm
Glynparry25
Thumbs Up Cheers, thought they might have found it confusing, lol.
Glyn Dog Sheep
Post #155915 16th Jul 2012 2:59pm
ZeDefender
Sorry for editing this post (yet) again but possible issues with LR built "quality" have cropped up.
Another member has found fitting the hinges a bit tricky doing everything with the bonnet on.
I lifted the bonnet off first. Here's what I suggest:
Fitting notes:
1) Remove the bonnet but don't fit the hinges yet until you know you can fit the bushings properly. Push the bushings into each side of the bulkhead hooks. If they are wonky or won't push together, the hooks are "off". In this case, insert the long bolt through the bushes and tighten gently, then remove the nut and pull the bolt out a bit so the two halves stay together. Pulling the bolt out a little means you can push the hinges partly over the bushings later.
2) If all is okay, fit the hinges to the bonnet, leaving them slightly loose so they can be adjusted later.
3) Put the bonnet back on (mine's bloody heavy with all the chequerplate Laughing) and ease it down and back until the hinge sides go partly over the bushes. This requires some patience as it is a tight fit. I used some blocks to support the bonnet at the sides or it would have dropped down too far. Watch out for the bonnet catch! It took a bit of wiggling and some confidence but once I'd got them in the right place, both sides went in fine. Then take the bolt out and push the hinges the rest of the way.
It would probably be much easier as a two-person job, lowering the bonnet down onto the hinges whilst holding the bushes firm (but I didn't have that luxury).
Let me know how you all get on.
Post #155921 16th Jul 2012 3:52pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Picked mine up yesterday, all in perfect nick.
Many thanks Matt for all your efforts (which I see now extend to fitting instructions, thanks again!)
Rob
Post #156083 17th Jul 2012 9:30am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Should I have got mine by now? No sign of them yet. Should I be panicking now Crying or Very sad
Post #156373 18th Jul 2012 9:33am
LR90XS2011
Matt
thanks, I've PMd you my address, I was on walk about trying to spot the Jack Wills defender in Cape Code and eastern USA a mission accomplished, all the best and thanks Rob
 DEFENDER 90 TDCI XS,
Post #156399 18th Jul 2012 11:07am
ZeDefender
Don't panic yet. It is my experience that DHL delivery times can vary by a few days (no idea why).
Also, 4 sets went out before the others (the first to pay Wink ) in crappy boxes. This includes defender4, I believe. Yours were sent at the weekend in a nice new box Thumbs Up Tell someone you love them today because life is short.
Post #156411 18th Jul 2012 11:55am
