Home > Maintenance & Modifications > grill surround
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
grill surround
Hi
My aunt had an accident with her 90... all solved now, she's rebuilding the 90...
I've managed to source almost every part (nearly new front axis, left wing, steering and panhard bars, and some other bits). But I have a doubt
the grill surround she had was like the def on the pic. But the one I got, used (as that new cost almos 200€!), does not have those square holes like the small pic on the right ... Are they needed? Or can I fit the grill surround without those holes...
 Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #155949 16th Jul 2012 5:26pm
K9F
The two apertures with all the holes in (if I'm on the right track and read your post correctly) are for the intercooler to get cooling air.
On the Puma they are large apertures and an aluminium grille is riveted into place behind the holes.
See here:
http://www.defender2.net/forum/topic8534.h...ler+grille
Not sure what the setup is on a previous model! Either way the holes are there for a reason and personaslly would not fit it without them. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #155966 16th Jul 2012 7:14pm
Those holes are on Td5 and puma defenders; for extra cooling (around the main radiator and intercooler), so if you work the vehicle hard your engine may get hotter.
For general bimbling around I can't see there would be any issue.
You just have a pre-Td5 surround there.
Post #155967 16th Jul 2012 7:15pm
lrmaniac
I thought that was the reason!
Thank you both! Thumbs Up
But that's an easy fix, to get those holes in to place, as seen on that other post ! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #155971 16th Jul 2012 7:40pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
but make sure its not for a right-hand drive fender Wink Putting Dreams on Drives at JLR Solihull..
Post #155982 16th Jul 2012 8:36pm
