Home > Puma (Tdci) > yeeehaaaa !
Page 1 of 3 123>
Caterham
yeeehaaaa !
I've probably tempted fate however I'm so excited I just had to share this with you.
although mentioned in other threads I don't think any of the subject related directly to this.....
after pulling my hair out for the last 18months trying to figure out whats been wrong with my car and everyone telling me its fine I think I've got to the bottom of it.....a loose ABS fuse.
granted it may still be early days to be 100% its resolved but early indications are good. the symptoms which I would describe as similar to fuel starvation appear to be resolved. although I would never have consider the abs fuse could impact on the engine running etc it would appear from another thread 'engine management / abs' that the two are linked (most of the discussion I have to say goes over my head tho Embarassed - diff-locks and the likes.....only just found out the defender comes with 4 wheel drive as standard).
so.....all in all one very happy bunny.
now thats sorted I can give some serious consideration to a BAS upgrade.....can any one tell my what the payback period is given I'm hoping to see a better return on fuel following a remap? Very Happy
Post #155097 11th Jul 2012 10:53pm
Bizarre, one of the difficult things of diagnosing over a forum Neutral
Glad you got to the bottom of it Thumbs Up QRZ M8VPF
Post #155099 11th Jul 2012 10:54pm
Caterham
me too - thanks.
(just hope I've not spoken too soon)
is there anyone out there that isn't too suprised to hear how the abs could impact on the running of the engine?
and is there anyone else out there thats had a similar issue??
Post #155103 11th Jul 2012 10:59pm
Nothing surprises me anymore...
Today I learnt that, to get an oil service light out on a mondeo, you turn ignition on and then press both accelerator and brake at same time for 15 seconds....the more I learn, the more I want a tdi !!! Or a v8 on boxer manifolds Cool QRZ M8VPF
Post #155111 11th Jul 2012 11:12pm
Glynparry25
Awesome news- I love it when you read something else and then it makes you realise what your problem is!!
As for the re-map... Don't know about BAS, but here are my figures with Alive map:
Without map: 25.5mpg (roughly)
With map: 28 mpg (roughly)
Average miles per year: 12,000
Gallons used without map (PA): 470.6
Gallons used with map (PA): 428.6
That is 42 Gallons less a year or 191 litres..... so I save about £200 a year on fuel ( but in uk that would be about £250ish)......
BUT- Even if I didn't save a penny on fuel it is still more than worth it!!!
Glyn Dog Sheep
Post #155126 12th Jul 2012 6:24am
Caterham
greeni,
like you say nothing suprises anymore - couldn't agree more........
in fact just the other night some little scrout drove about 200 yrd from his house into 'our' road pulled up and dumped all his rubbish in his car onto our pavement !!! Evil or Very Mad
Gly
it took sometime and bearing in mind I had for sometime thought it could be electrical I didn't think of the obvious - fuses. was convinced it was an electrical part or the wiring loom.
interesting on the map. excellent even. did you have it mapped for economy ?
Thumbs Up
and Thumbs Up to everyone that and helped and Thumbs Up to everyone hearing about my constant moaning.
another drive in the motor this morning and its still looking like problem solved Thumbs Up Thumbs Up Thumbs Up
Post #155127 12th Jul 2012 6:38am
Glynparry25
I had it re-mapped for power....... economy seems to be a by-product.
I do a lot of off-road, motorway, towing and just general heavy duty driving so wanted more power to help- plus have a roll cage, 285s and a whole load of other bolt-ons which slow it down.
Glyn Dog Sheep
Post #155193 12th Jul 2012 11:44am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Quote:
a loose ABS fuse
Think I might check mine now
Post #155203 12th Jul 2012 12:29pm
totoD110
The Boy wrote:
Quote:
a loose ABS fuse
sir,
where can I locate this ABS FUSE so that I can inspect it as well? TIA
Post #155340 13th Jul 2012 3:44am
Caterham
the fuse is under the steering wheel. from memory its 1 up from the bottom of the column second from right.
not sure how to break this tho.........
I'm no longer convinced its solved the problem......jury is still out on this
Big Cry
will hopefully get a few miles on the clock this weekend and keep you updated.
Post #155357 13th Jul 2012 8:17am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Could anyone (Gary or Pete maybe) confirm this link between ABS fuse and ECU behavior?
Guess this should be in the OEM coding or linked to the electrics (eg engine sensor which takes its power from same line as ABS)
The reason i am asking is that i have a switch inline with the fuse to disable TC if i like.
I drove the car also multiple times on-road with ABS/TC disabled (so same as if the fuse was taken out) and I have nill effects on the Engine/ecu from this.
Don't want to spoil the yeeehaaa, just looking for confirmation.
Smile
Post #155360 13th Jul 2012 8:27am
Caterham
Big Cry
as above I've a horrible feeling.......
Post #155363 13th Jul 2012 8:42am
K9F
Hope it wasn't the case of premature 'ejacelebration'........ Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #155366 13th Jul 2012 9:07am
It may be that the problem is caused by it switching rapidly and intermittently, i.e., a poor connection, rather than a steady state on/off.
In view of what I found in my under-column fuse box I would recommend everyone checking theirs at some stage, especially if strange behaviour is being experienced. As I posted elsewhere, when I removed the 'sellotape' that had been put over the fuses apparently at build time to secure them, at least half the fuses in the fusebox simply fell out.
Post #155373 13th Jul 2012 9:33am
tatra805
Shocked
And i thought the 'sellotape' was a genius piece of high level LR engineering in making the best 4x4xfar Rolling with laughter
Post #155379 13th Jul 2012 9:58am
Page 1 of 3 123>
