Home > Maintenance & Modifications > Quality Loadspace Matting
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
I'm about to fit a MSS drawer system to my 110 Puma together with the wheel arch spacers to give me a flat load area in the back. The top will be checkerplate but I'd like to get a good quality rubber mat that I could fit across the whole lot.
The mat would need to be thick enough to lay flat without adhesive and I'd be looking to pop rivet an aluminium strip front and back of the to of the drawer top so it doesn't move.
Anyone found anything suitable that didn't cost the earth?
Thanks
Mark
Post #155230 12th Jul 2012 4:14pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Try stable mat from SCATS It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #155242 12th Jul 2012 4:55pm
Zagato
I bought a stable mat from Scats but took it back as it was soooo heavy, too thick for my needs and difficult to bend. Machine Mart do matting lighter non smelly matting. It's the standard lining material you see quite often, 6mm I think. All depends how hard the use will be I think.
Post #155261 12th Jul 2012 5:18pm
Bear in mind that the thinner it is the weaker it is though. Mine is thin (not purchased by me) But anyway mine is thin and has ripped on the edge where it is ribbed. Not good! I doubt you can beat the Genuine LR one from Dan but the price is high Shocked _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #155272 12th Jul 2012 5:47pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Exclamation Be careful if you do a google search for 'scat mat' mind you...... also avoid glass topped coffee table Wink 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #155278 12th Jul 2012 6:15pm
The genuine rear mat is currently on offer so worth a look: http://www.duckworthparts.co.uk/landrover/...ction.html
If I had to buy another this would be my choice. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #155282 12th Jul 2012 6:42pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Are the genuine LR ones designed to go between the wheel arches? If so won't they be a bit narrow if OP has levelled the back with a drawer unit?
Post #155303 12th Jul 2012 8:34pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I got some 3mm rubber from Machine Mart. They have different thicknesses and was the cheapest I could find. Thumbs Up 2008 110 XS CSW Stornoway Grey
Post #155325 12th Jul 2012 10:19pm
Lukey Boy
Sorry Zag - just read your post. Embarassed 2008 110 XS CSW Stornoway Grey
Post #155327 12th Jul 2012 10:20pm
sparkylee
This might be of some use
http://www.ebay.co.uk/itm/BS921-Electrical..._500wt_922 It's good to be back from the dark side
FFRR 4.2 vogue
Post #155328 12th Jul 2012 10:21pm
The LR genuine is indeed designed for between the arches so for this particular use then it would be too narrow like you say sadly. For every one else though including myself it's a perfect solution. Anyone got one? _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #155329 12th Jul 2012 10:24pm
JSG
Yes, I've had genuine load area mats in all my Defenders other then the Tomb Raiders. John
2011 Tdci 110 CSW XS
Post #155339 13th Jul 2012 12:51am
SGH
Try here they cut to size I have the hammer mat in the rear of my work vans and my 130 Thumbs Up
http://www.rubbermattinguk.co.uk 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #155342 13th Jul 2012 6:49am
vaucluse
Thanks for all your suggestions guys.
I think most of those stable type mats are way too thick and heavy. At 18mm in thickness and around 6ft x 4ft they weigh in at around 40 to 50Kg!!!
I have this morning spoken to a car carpet mat manufacturer who given that I need a rectangular mat around 1.5m x 1m can make a custom premium quality mat for £22.50 plus carriage which seems really reasonable.
i think that's the way to go for me.
Thanks again,
Mark
Post #155893 16th Jul 2012 12:58pm
fixit
Hi could you let us know who it was you got the mat from and may be a pic Cheers
Post #156549 18th Jul 2012 8:02pm
