Home > Puma (Tdci) > 2007 2.4 Defender Stalling no power
standard_Man
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tamar Blue
Wife went to leave this morning and it just won't run stalling and wont rev. Got to the end of the street and limped back. Struggled to get it on the drive with a mild slope.
Any ideas ??? Had the car 4 weeks private sale, done about 1000 miles since purchase.
Post #155170 12th Jul 2012 9:44am
wslr
Fuel quantity sensor/Valve on the back of the diesel pump? Otherwise, EGR or other fuel issue.
Post #155177 12th Jul 2012 10:27am
K9F
Doesn't really help in your circumstance but it would be well-worth the investment in a Scangauge, or another diagnostic tool...The scangauge would pay for itself first time you have any issues! EGR would be a guess as they are notoriously problematic and can cause all sorts of running issues.
There may be another Wiltshire forum member that may be able to assist perhaps? Do you have MIL (engine management) light illuminated? Quick call to dealer otherwise.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #155180 12th Jul 2012 10:40am
Caterham
real long shot this.....don't suppose its got EEG in the registration has it?
I had a blue 110 which headed off to your part of the world.
it had various problems which included silicone on the wiring loom connectors and various other issues. after my recent problems my first point of call for something like this would be to check all the fuses are in place / haven't blown (easy job and if nothing else rules this out).
good luck.
Post #155182 12th Jul 2012 10:43am
landy andy
Hello and welcome, glad you found us, and hope we can help you with our problem.
Andy
Post #155186 12th Jul 2012 11:10am
standard_Man
Nope
Not that one (Thankfully)
Post #155188 12th Jul 2012 11:18am
Nugget
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I had what sounds like a similar problem a couple of years back on my 2008 2.4.
Cruising down the freeway, packed to the gunnels with family, dog and camping gear and the engine just quit. Engine would start but would quit again once you built up the rev’s. Checked fuses, fuel and all usual suspects, nothing.
Tow truck job back to the dealer under warranty.
I spent a bit of time with the work shop foreman when I went to pick the vehicle up after the repairs to get the low down on the fault. Being a mechanic I felt a bit stupid not being able to repair my own car. Especially with Mum and the kids stranded on the side of the road. Embarassed
Anyway he told me that it was a loose fuel injector connection of #4 cylinder. To this day I’m skeptical, but seeing as I’ve been out of the car trade for over twenty years. I think is plausible?
Maybe something easy you could check? 2008 110 SVX Defender
The Black Truck
Post #155696 15th Jul 2012 11:03am
standard_Man
Thanks for the suggestions.
The garage changed the fuel filter and a valve on the common rail of the diesel apparently and all should be fine now.
Post #156479 18th Jul 2012 4:16pm
That's not a great Super Hero name Wink
Post #156481 18th Jul 2012 4:19pm
Caterham
can anyone tell me how easy it is to replace the common rail valve.....does the ecu need to go through the learn process?
what about getting air in top the fuel system (hopefully not too much of an issue being the highest point)
and can anyone tell the cost of said valve ?
Post #156650 19th Jul 2012 7:56am
wslr
The fuel rail itself has a fuel pressure (at the rail) sensor at the front, and a mechanical fuel pressure relief valve, which once activated needs to be renewed.
I suspect the OP is referring to the fuel metering valve/fuel quantity valve/volume control valve on the rear of the fuel pump. Sorry about all the names, but obviously more than one department worked on this and never decided on just one common term!
The VCV is LR009837 and costs £99.84 + VAT
RTS book time is 0.3, but probably more like 45 minutes to get everything out of the way to get to it. Rolling Eyes
Yes, once the VCV is fitted, a calibration/pump learn needs doing.
Post #156678 19th Jul 2012 10:22am
