![]() | Home > Puma (Tdci) > Engine management and brakes |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Indeed, but during these descents you are not using the accelerator, so there is no driver throttle input to the ECU? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
naks, correct but the ECU is telling the engine to accelerate (engage anti-stall) despite the driver input indicating he wants to slow down the car.
I am convinced the drive by wire technology must have a safety net when conflicting signals occur, whereas the brake signal has the priority above the accelerator. Now if this system would work identically with difflock engaged when the anti-stall is working ecu should disable the anti-stall if you press the brake longer than 5sec. but it doesnt therefore i suspect this conflicting signals priority thing to be disabled with difflock engaged. If so, this solves the ATB diff issue (i have them also) of blackwolf. edit: It could be that the anti-stall has priority over brake signal (or is ignored in the programming) but this would create unsafe situations in normal driving when pressing the brake without pushing the clutch eg in a panic reaction. Anti-stall would keep propelling the car even when you are braking... if this is the case i consider it very poor programming and an issue (as a failure in the brake system (eg accident) could mean brakes are not able to overcome power of engine to stall it) As a sidenote it's not the best idea not to use your center difflock offroad as the LT230 center diff is strong when locked but was not designed for prolonged exposure to different speeds between front and back axle (so offroad unlocked) |
Pretty sure that is the case, LR is not *that* stupid ![]()
Eh? I disagree, as soon as you step off the black stuff, put your CDL on. I have driven for over a week with the CDL locked in various parks, no issues whatsoever. Also, with the CDL locked, front axle speed = rear axle speed ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
eh... yep! thats what i said didn't i?
and about LR being "that" stupid i am.... let's say... open for arguments ![]() ![]() |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 ![]() ![]() ![]() |
Just tried this in my 2011 Ford Transit with the 2.4 TDCi. Power is cut after about 5 seconds at normal speeds so it is engine management related. Haven't checked at low speeds.
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
With the anti-stall feature on the Defender, this video makes interesting watching as the 110 drops down a slope.
http://www.youtube.com/watch?v=PMhOhT5nwZk Issue starts at around 4:10. Not sure if this is relevant to our discussion? |
That was the driver doing it on purpose to illustrate what could happen. IRL in 1st low, you brake during a descent and it does not accelerate ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ashley110 Member Since: 21 Mar 2012 Location: Johannesburg Posts: 7 ![]() ![]() ![]() |
I can down Sani and on switch backs etc I used 1 and 2 Low on engine compression.
The car did not even vaguely respond like it does in that video. |
BW you mentioned the brake connection c0075r-2 Can you explain what is also connected a 'header (k109)'. Kind it's an point then can't see how this works? ![]() |
