![]() | Home > My Defender > IKke's military 90 |
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 ![]() ![]() ![]() |
Yes I've thought about it. And every time I was working on this outrigger I was thinking "A galvanized chassis would sort all (future) chassis rust problems". But I can't really justify it because it's only this outrigger that is rotten away.
There is 1 small hole the size of a pound coin in the other, but the rest of the chassis is pretty solid. All the rest of the rust (as far as I've seen) is only light or surface rust. So i'm gonna paint the chassis with hamerite and than waxoil it. One day when I have some more money (still a poor student now) I'll build my own landy from the ground up ![]() |
Today was W-day. Indeed welding day. I got up extra early to remove the last bit of outrigger using the hand saw and a file because a friend would come over to weld on the outrigger at 2 p.m.
So when he arrived I tried the outrigger on, uhm... that didn't really fit properly... When we put a 12mm rod in the 2 holes/tubes to line up the outrigger to the bulkhead the outrigger would leave a huge gap above the chassis on the rear side of the outrigger ![]() Hint: the parasol isn't for the sun ![]() ![]() Click image to enlarge ![]() Click image to enlarge And the result. Welding was done with a mig welder using a wire that need no gas. It does leave a bit of white dust but that easily wipes off. ![]() Click image to enlarge Sorry for this badly focused photo. ![]() Click image to enlarge And with a blop of paint on the welds. ![]() Click image to enlarge Scaling the real deal. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2741 ![]() ![]() |
Well done, better welding than mine! Hate welding under cars, I can do really good stuff on the bench but it's a different game under there.
PS. I thought you said 'wedding day' in the first line of your post, now welding an outrigger onto your Land Rover on your wedding day... that would be living dangerously! |
![]() ![]() But back to welding. The quality of the welds is the reason I'd asked a friend, and particulary this friend to weld it. He is an amazingly experienced and knowledgeable fabricator. He welds also has alot of welding experience from cast iron to welding stainless steel boilers for scale steam trains. He even said that these welds didn't look very nice and that next time we should clean the surfaces (paint/rust) better and use gas to weld it. I'm happy with the result anyway ![]() |
tiny update
The whole front end is painted and wax oiled. Only the rear area from the rear outriggers to the bumpers left. Before: ![]() Click image to enlarge After removing rust and painting. Before waxoiling. ![]() Click image to enlarge Scaling the real deal. Last edited by IKke on 28th Jul 2012 11:37pm. Edited 1 time in total |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
Coming along very nicely! Keep the reports coming!
![]() 2008 SWB Truck Cab 1952 80" Soft top |
Nice work!
![]() Well done! ![]() Treat every day as if it is your last....one day you will be right!! |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
No, my chassis is good. I just appreciate it when people make the effort to do a report on something ![]() To me, the older trucks seem far more interesting than the newer ones. Incidentally, I drove past a house the other day and it was full of old dead land rovers ![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
@K9F: You bet I can't wait. I actually was a bit done with the landy. But then I had to move it to the other side of the driveway. And being able to drive it again made me see why I did all the work.
![]() @chiefstoker: They are quite more costly. But being a 1986 it's one of the last (road) tax free land rovers over here saving me €1800 a year in roadtax. Which makes it quite worthwhile. Especially when I plan on keeping it long term. And I'll get some more pictures when I get back working on it. A last upside is that i finally got it insured. Again quite a bit more then(than?) I was hoping for at €700. I tried to insure it as an oldtimer but was unable to do so because I'm under 24 and don't own any other cars and have zero damage free years on my name. So all by all the 700 is not to bad I guess. ![]() |
Another tiny update.
I just love how nice and black the front end is. ![]() Click image to enlarge ![]() Click image to enlarge And now the rear right section is also de-rusted and painted. ![]() Click image to enlarge And the rear cross member and 3 link bar is also nicely painted ![]() Click image to enlarge And I also discovered this little light near the rear diff, anyone know why the army fitted these? ![]() Click image to enlarge Scaling the real deal. |
Nice work Ikke! I think the light is for illuminating the back of the rear diff, which was painted white, this was used in war conditions when driving in colonne. That way the vehicle driving behind you could see you if no driving lights were used at night in war conditions. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
That explains, cause they light up with lights on convoy setting. And there was white piant on the rear diff. Cheers for that.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
Yup, that's your convoy light. As mentioned, for tactical night driving. The lamp should rotate with a large hole and a small hole to allow the light out, so you can make it really "dim".
But the method is, you have convoy mode on, and following vehicles can see where you are and follow... makes for interesting cross country driving sometimes. i remember doing it in a Bedford 4 tonner... and the person behind me (driving the same) forgot to stop.... ![]() |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
Great project! Good luck with it.
