Home > Puma (Tdci) > LAND ROVER DEFENDER 2011 - USELESS OFF ROAD
Andrea
Hey guys,
I have a 2009 Defender 90, it is unstoppable off road. I recently bought a 2011 Defender 90 and it is USELESS off road- it could not keep up with a 95 defender.!!!!!!!!!!!!! I have spoken to LAND ROVER regarding this issue and they have said to me that there is nothing wrong with the viechle and the traction control was upgraded so as to only activate over 8 kms / hour!!!!!!!!!!!! Please advise can somebody help me, before i sell this thing???
Post #154512 9th Jul 2012 2:52pm
More details, what type of terrain? QRZ 2e0vpf
Post #154521 9th Jul 2012 3:36pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
2 cents:
stock to stock same specs tires etc: driving style with TC adaptation not completed, allow time to get used to the TC
(i'm not the prophet telling you how to drive best with TC, as it is very dependent on the terrain)
mod: pull out the TC fuse and compare again, should be the same, there is no reason why it should be different.(evt fab up an inline switch so you can disable it on the fly/as you wish)
TC helps in a majority of cases, in some not. but overall it should be an improvement over non-TC if driven correctly.
If your 2011 has stabi bars front and rearwe are comparing apples and oranges. These will limit offroad performance (articulation is the word) drastically.
mod: remove them if you dont care about decreased on-road behavior or put in ATB's or evt full lockers to compensate for it while retaining on-road manners
give it a chance, i would not go back to non TC
an opinion only
Smile
Post #154523 9th Jul 2012 3:40pm
JSG
What is the difference between both of them spec wise?
My 2011 110 is just as good as my 2007 110 was. The Defender is very capable 'straight out of the box' so I'm surprised to hear your problems. John
2011 Tdci 110 CSW XS
Post #154532 9th Jul 2012 4:10pm
Naks
Re: LAND ROVER DEFENDER 2011 - USELESS OFF ROAD
I find this odd.
My 2010 90 would be the same spec as your 2009, and on every single Cape LR Club outing, performance of mine is no different to the newer models.
Were the following identical?
1. Trail
2. Weather
3. Tyre pressure
Also, did you confirm that your CDL is working? --
Post #154533 9th Jul 2012 4:14pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I think the nut behind the wheel may have change across the MY's - Maybe this has something to do with it? 2002 Defender 110 DC
Post #154535 9th Jul 2012 4:17pm
farmer giles
Post #154538 9th Jul 2012 4:59pm
I always though TC = talent control Whistle Wink
Post #154539 9th Jul 2012 5:15pm
ericvv
Post #154544 9th Jul 2012 5:58pm
I have a 95 defender 90/300tdi ... I'd consider a swap Thumbs Up
Post #154546 9th Jul 2012 6:00pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
That was posted in 2010 which, I'd guess, was prior to replacing it with a 2011 Defender ?
As for the OP I suspect that it's just a matter of adapting to the new TC software. The increase in speed before it cuts in is probably a reaction to customers removing the fuse to stop the TC bogging them down. There's nothing else different in the drive train between the two.
Maybe try being a bit more aggressive with the throttle when you want the traction control to kick in.
Post #154550 9th Jul 2012 6:14pm
Andrea
Well as I said I have 2 defenders. the first is a 2009 defender 90, which is still an incredible machine I have never driven anything like it, the other is my 2011 defender 90 for the lady.
We took both landies out to meogatle this weekend and on the rough sections , axle twister, the 09 sails through and the 11 gets stuck and just bounces around. I have extensive experience in driving these traction control equipped landies and as I say my 09 is an absolute pleasure. I also had a disco with traction control which was a pleasure too!!
The 11 went to land rover and they reported back to me that early in 2011 the traction control system changed from Wabco to Bosch and according to land rover the Bosch system does not kick in under 10 Kms per hour.. On these axle twisters you barely do 1km/hour????
I can't believe that they have made the car worse, which is exactly what Landy is telling me??? Are You guys battling on seriously rough terrain with the Bosch systems???
I love landies I just hate being overtaken by lcs off road Big Cry
Post #154556 9th Jul 2012 7:15pm
Andrea
Sorry the terrain was loose gravel, axle twisters on inclines. I drove the 09 through the obstacle... No problem, I then got into the 11 and couldn't make it???
Post #154563 9th Jul 2012 7:42pm
ZeDefender
Hi Andrea
Still learning about this stuff so forgive me if this is a stupid question:
Loads of people seem to want to turn their TC off for off-roading but do I understand that your problem is that the new Bosch system does not turn it on at low enough speeds?
Do you know at what speed the Wabco system cuts in?
Might it be possible for the dealer to tweak the software of the Bosch unit?
Matt Tell someone you love them today because life is short.
Post #154566 9th Jul 2012 7:49pm
tatra805
i'll repeat myself, what about the sway bars / stabi bars? both your defenders have them?
makes a huge difference, as you know
I used to drive without them on older defenders and i really see the limitations they bring on the current 110. You'll be surprised how drastic these bars are limiting articulation and thus offroad capabilities.
as you say you are driving below 10km/h so which system you have should not make a difference, unless you have wheelspin which is higher than 10km/h, but i understand from your writing thats not the case?
would be nice for others too know what causes your problem is, so dont take it all too personal.
I am driving things as you describe and worse. One of the reasons i went for ATB diffs is the influence of the sway bars offroad (which i dont want to take off as i prefer the road handling esp when towing). The diffs make up for that.
Smile
Post #154568 9th Jul 2012 8:01pm
