Home > Puma (Tdci) > Stone Chips
brightondefender
2010 Defender 90 Puma 2.4 XS CSW Alaska White
Stone Chips
Since getting a Defender I have noticed that when a stone is thrown up by the rear wheels it makes an almighty noise in the rear. Is there anything that can be done by putting some sound proofing under the carpet or in the rear wheel arches?
It actually doesn't bother me to much, but sends my 2 dogs wild and now they are really reluctant to get in to the Defender.
Thanks in advance for any help Very Happy
Post #154291 8th Jul 2012 11:31am
Killer90
Site Sponsor
happens still with soundproofing, im guessing you could make an extended rubber mudflap of some sort even one hidden up a little higher as its the stones flicking from the tyres upwards Thumbs Up
Post #154315 8th Jul 2012 2:08pm
Zagato
Layers of stone chip paint helps. As I had a tin left over I used 'Waxoyl Stone Chip' gloop just for the inner arches Thumbs Up Slap plenty on letting the coats dry well in between applications.
Post #154320 8th Jul 2012 2:54pm
my 110 has cowmatting (very thick, 15mm or so rubber mat) and plywood on top of that inside, and I still hear it!
Post #154325 8th Jul 2012 3:06pm
ericvv
Wouldn't Entreq wheel housing splash plates help here? I am thinking of getting them, worth your while you think to reduce the noise from stones being thrown up by the tires Question The Entreq splash plates set for a 110 is quite well priced I think, so what think Question
Here is what I refer to:
http://www.entreq.de/products/protection/r...e=english# You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #154327 8th Jul 2012 3:07pm
Happyoldgit
A liberal coat or two of Schutz stone chip paint on the exterior of the wheelarch panels helps. Steve.
http://forums.lr4x4.com
Post #154335 8th Jul 2012 4:14pm
K9F
Has your Defender been waxoyled? Mine used to do the same as the stones are impacting against a painted metal surface. As stated a couple of layers of waxoyl under the arches will deaden the impact.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154373 8th Jul 2012 7:02pm
MK
Sticking 3 mm thick EVA rubber works a treat Puma 110" SW
Post #154634 10th Jul 2012 12:39am
brightondefender
Thank you for anyone who has posted a reply, I have had the wheel arches waxoiled and I will update the post once I have run it for a few weeks. May also get some noise killer in the boot area.
Post #155565 14th Jul 2012 4:53pm
