![]() | Home > Puma (Tdci) > over run between gears |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6331 ![]() ![]() ![]() |
Landylad - sorry if you think I've hi-jacked this thread.....
![]() i didnt want to start ANOTHER thread because of possibly ![]() so here goes - can anyone tell me what would cause the engine to stop nice and smoothly.....or NOT. ? thanks in anticipation. |
Landylad,
many thanks. I hope you enjoy driving now your mind has been put to rest. .....and I hope to get to the bottom of things too. can anyone confirm if the switch on the clutch cylinder should be n/o or n/c when the clutch isn't depressed ? |
so tried it with the clutch connection unplugged and not nice. the over run between gears was massively excessive and really not nice.......
so where does that leave me? I presume that means its working correctly? ![]() |
Andrea Member Since: 02 Sep 2010 Location: South Africa Posts: 30 ![]() ![]() ![]() |
Mate this is such a simple fix, had the exact issue on mine. Check the fuses, its usually the trailer ligh fuse that blows... causes this issue!!! Dont ask me why but it does!
Hope this helps!!!! |
Andrea. thank you very much.
just before I go outside and get soaking wet where was the fuse (under the drivers seat?) thank you. |
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 ![]() ![]() ![]() |
i have exactly the same landylad.....drove out of the showroom Brandnew defender 2,2 and it did that.
so far i just left it thought it might correct itself. my guess that it's a electronic issue of some sort. i got used to it now but if anybody knows of any (landrover recall) do let me know and i'll mention it when the first service is due. LANDROVER Defender Best 4 x 4 x Far Defender TD4 90 Hardtop 2.4 Defender TD4 110 Hardtop 2.2 |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
http://www.defender2.net/forum/topic10532.html?highlight=revving
May also be a powertrain software issue fixed by a later version? |
Andrea,
have checked most of the fuses will check rest later today (all ok so far and to be honest the trailer lights works so don't think it relates to this). wslr - will have a look at the clutch fluid also - thanks. |
This particular one wouldn't keep its fluid clean, even after a flush, so we fitted a new master cylinder. IIRC, it had some work done elsewhere including the clutch/slave, so this was OK(ish), but a new master cylinder sorted it out as far as I know.
interesting....thank you.
Sorry to get back to you so late. I would check those under the wheel it is often there that a fuse blows. It's normally the red fuses. Come to think about it my trailer lights where also working when it happened so ya maybe just check those. If not then wslr seems to have the next best solution.
Andrea
many thanks for suggesting fuses......... I've had a look through and non had blown...... however I did find something interesting - so much so I'm going to start another thread asking for information on fuses - so if interested have a look on tdci f40 fuse !! ![]() thanks again. |
