Home > Technical > What snorkel sealant?
Page 1 of 3 123>
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
If I ever get my Safari snorkel sorted out what would you recommend I should seal it with? I know many say you should use marine sealant but I can�t get that at B&Q, so what brand or sort that is readily available should I go for?
Post #154134 7th Jul 2012 12:46pm
K9F
Is it a B & Q stock item you're after or the stuff best suited to your needs? Sikaflex is available on line....
http://www.ebay.co.uk/itm/Sikaflex-291-Fas...2219117121
Sikaflex 29i is for me the best sealant available. If it's good enough for one of these....
It's more than good enough for one of these...
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154139 7th Jul 2012 12:59pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
I used 3M 4200 adhesive sealant on the company D3 (had some left over from fitting out the fleet of RIBs,so thought I would use it up), and would definitely recommend it having had no problems on either boats or the truck.
If you can't get hold of it, online chandlers such as Force4 or Mailspeedmarine usually stock it (or eb*y...)
http://www.mailspeedmarine.com/marine-seal...7873.bhtml
Post #154141 7th Jul 2012 1:11pm
The Boy
Just been all over trying to find one of those so will order on line and hopefully fit next weekend Thumbs Up
Thanks
Post #154153 7th Jul 2012 3:28pm
Grockle
Mal,it can't be that good because it's fallen off the ferry Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #154160 7th Jul 2012 4:24pm
The Boy
OK so I have just spent three hours trying to get the old Matec/LR RAI off. One of the rivinut had seized and it was the one that you can't get to behind the antilock block. Anyway it is off now, and it wasn't in a very good state. The bottom of the snorkel has worn away the paint on the wing but the new one should cover that. The problem now I have is the sealant they have used I just can't get it off! I put a heat gun on it to see if it would soffen it enough to peal it back but it didn't and is stuck fast! Any idea of what to use to get rid of it without recking the paint work?
Post #154179 7th Jul 2012 6:37pm
K9F
Looks like a resin or Araldite in the lower edge. I would suggest trying a scalpel or a Stanley knife blade to try to get behing it and carefully peel or slice it off. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154180 7th Jul 2012 6:40pm
TR51
I agree with K9F. Thumbs Up
If it doesn't work try dabbing it with ascertone to degrade the bond (although it shouldn't have ANY effect on the metal, try it on an area that you can't see first etc... Thumbs Up )
Post #154183 7th Jul 2012 7:04pm
bob neville
Acetone may remove it if resin based.
Nick the wifes nail polish remover under the cover of darkness and try that - they are normally acetone based Thumbs Up
You may want to put a small amount on a hidden area of paint first to make sure it does not remove that as well Shocked
Alex types faster than I do Laughing
2013 Defender 90 CSW - sold
Post #154184 7th Jul 2012 7:04pm
TR51
Off Topic Great minds think alike Whistle
Post #154185 7th Jul 2012 7:08pm
K9F
Even if you can't get it all off as long as you get the majority off together with the lumps and bumps you can form a new bed of sealant over the old when you fit the replacement, if you don't wish to seal it the gasket will cover it. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154190 7th Jul 2012 7:33pm
The Boy
Man this stuff is like conrete Rolling Eyes It just wont shift!!! nearly an hour and I've removed less than 5% of it Shocked
Just nicked Wifeys nail polish remover and will have a go at that.
Thank for the tip I'll report back.
Wish I had never started it now.
Post #154195 7th Jul 2012 7:40pm
K9F
Is it resin based and rock hard or is it still flexible? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154196 7th Jul 2012 7:42pm
bob neville
I told you to wait until after dark, you will be in trouble now Laughing
Put some on a small area and leave it for 30 minutes and see if it has softened it. Depending on exactly what they have used if may take quite a long soak time to be any use.
Post #154197 7th Jul 2012 7:44pm
K9F
Just reread the thread, as it's like concrete if you've a wallpaper scraper to hand place it on the inner edge and a careful sharp tap with the pointed corner should free it up. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154199 7th Jul 2012 7:47pm
Page 1 of 3 123>
