Home > Maintenance & Modifications > X-Trouser- daft name, clever idea
Page 2 of 3 <123>
SGH
Bet they don't stop seat belt getting Censored though Big Cry 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #152475 28th Jun 2012 5:09pm
SimonR
I could feel my ears burning - so though I'd register and answer some of the questions raised here!
Although they don't entirely stop the seatbelt being damaged when it gets trapped in the latch - it doesn't get caught so often and when it does it suffers less damage as there are fewer sharp edges.
I have another simple solution to the seat belt damage issue and that is just to attach a plastic rectangle to the belt where it would get trapped. The door bounces off the plastic and doesn't trap the belt. It also seems to help stop it getting trapped. I cut one out of a piece of HDPE sheet I had lying around.
Can you use it as a bottle opener? Yes! That was a design requirement!
Proof here: http://img843.imageshack.us/img843/259/3yso.mp4
Someone suggested just sanding the edge off the original catch to smooth out the hook. Although this works, and it's what I originally tried, it weakens the catch to the extent that one day it let go when I leaned on the door! It was one of the motivations for trying to do it properly!
Lastly, I agree that re-aligning the catch can be tricky. What I've done in the past is to draw round the riser block with a marker then when you fit the new one, it's easy to get it in exactly the same location.
Someone mentioned about spraying WD40 into the lock if the door doesn't close properly. This is an excellent thing to do - and one of the 'tricks of the trade'! Most door closure problems that are blamed on latch alignment are in fact just the lock mechanism getting sticky. If you take it to a dealer to 'fix' it, chances are they will just cover it in WD40 then spray grease.
I'll do my best to make a positive contribution here even though I only have a Defender 1.5 (A late Td5 is well on the way to a Puma). Sadly, I just don't fit in Puma's - and my wife looked dismayed when I suggested buying one and taking a Jig-saw to the Dash to fit my knees in!
Si
Post #152483 28th Jun 2012 5:59pm
Plenty of TD5 owners here Cool
Ok, 75% success rate. Both front doors fitted without issue. Rear drivers side door fitted too, although I noted that the mounting block had two alloy shims underneath. No shims on the rear passenger side though and because the new catch is slightly thinner than the original, i.e. the post is shorter, the door wouldn't close over it. I'll have to source (or make) some shims before I can fit the last one.
Before and after:
Observations:
The sound that the door makes when closing changes slightly, although not unpleasantly.
The existing catches have various nicks and marks on the inboard parts of the 'loop' whereas the new ones have longer loops so there's less chance of contact.
All in all, very pleased Thumbs Up Darren
Post #152495 28th Jun 2012 6:50pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Shocked Shocked Shocked Shocked Shocked
don't applogise to this lot about only having a TD5, by far the better vehicle Whistle
Laughing Laughing Laughing Laughing Laughing Laughing
Post #152502 28th Jun 2012 7:01pm
SimonR
I think both have plus and minus points - the one thing I would really like is air vents that blow where you want them. But I dare say I could knock something up one day When I have a spare afternoon.
I had to make the pin 1.5mm shorter so that the domed end of the bolt would fit. It was a compromise - but a necessary one. I plan on ordering shims and supplying a couple with the X-Trousers just in case. You can loosen the hinge bolts and move the door a couple of mm - but I guess that's a whole other can of worms!
Si
Post #152551 28th Jun 2012 9:08pm
I could...but I think I'll just use shims on the catch Shocked Darren
Post #152566 28th Jun 2012 9:30pm
TJ101
Welcome Si
Good to see you here Very Happy
Catch you tomorrow Whistle Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #152577 28th Jun 2012 9:44pm
SimonR
If any of you are coming on the trip to the Isle of Wight tomorrow - ill bring along a few as free 'samples'.
Si
Post #152586 28th Jun 2012 10:00pm
TJ101
Si
Whistle Bow down California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #152590 28th Jun 2012 10:02pm
ZeDefender
Think I might get some just 'cos of that video Laughing
p.s. thanks again for all that handbrake info you gave me - it's been immensely useful.
Now I only have to wait 2 more years to fit the X-Brake Thumbs Up Tell someone you love them today because life is short.
Post #152591 28th Jun 2012 10:06pm
Martin
Site Admin
Simon - please be aware of this site's commercial posting/promotion rules: http://www.defender2.net/forum/topic275.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #152607 28th Jun 2012 10:50pm
SimonR
Martin, I had read the rules and thought what I had posted fell under the term:
"Your post is an entirely informational reply to a request or question posted by a site member who is not associated with your company. "
It's not my intention to promote said company - but I appreciate that even in answering questions it's a fine line.
Si
Post #152620 28th Jun 2012 11:57pm
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
Si
Morning Si,
Will have to drop round at some point and pick some up - I am afraid I did the Isle of Wight last weekend, so wasn't planning to go again this weekend... Wink
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #152664 29th Jun 2012 9:27am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
just ordered me some, will see how we go. Rhubarb and custard let fly with their secret weapon.
Post #153954 6th Jul 2012 4:41pm
ZeDefender wrote:
I'm going to need to investigate this - I've never got my trousers caught and I'm worried I may be doing something wrong Wink
Like wearing a skirt? Thumbs Up QRZ 2e0vpf
Post #153960 6th Jul 2012 5:21pm
Page 2 of 3 <123>
