![]() | Home > Technical > rear immatriculation plate fixation |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hi,
let me tel you first that this is a stuppid question , I know. I have receive my new defender 110 and the mechanic who know me very well did not attach the plate at the back , left side of the defender because he know that I prefer do it my self. the problem I have now is that I do not know how ! I would like to use plastic screws to be sure there is no corrosion but I do not know how to take of the plastic where there is the rear speaker. there are some plastic screw but when I have try to take them off with my screwdriver, they did not turn at all thans for your comments philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
They are fixed on with double sided padded sticky tape. just give it a good pull across the top.
thanks Greeni !
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
How the plate is fixed will depend on your supplying dealer, as they are fitted by them and not at the factory.
You say there are screws in place so I wouldn't just pull the plate off ![]() ![]() ![]() |
Hi,
to try to be a little more clear, I have a support plate wtih holes , so , I did think to fix it with screws. but I will try to find double sided sticky tape ... (sorry for my english... ) Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
