Home > Technical > ETC or no ETC
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
ETC or no ETC
In the plan to acquire the 2.2 Puma, the top of the range has ABS and ETC but the entry level dont. I usually understand that any form of LSD or non standard open differential, will make a swap in to LSD, or like ARB lockers very difficult or impossible?
Has anyone installed a locker in the 2.2 yet?
Post #152824 30th Jun 2012 1:48am
not yet, but before you buy, have a look at ashcroft LSD's
Post #152829 30th Jun 2012 7:08am
ronwong
i am asking because i do appreciate the ETC. but it is very likely i go the arb locker way, so i dont want to have to swap the whole axle
Post #152839 30th Jun 2012 9:27am
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
I may be wrong Embarassed but ETC is only on the front axle, therefore you could put a locker on the rear with no problem.
Post #152859 30th Jun 2012 12:45pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
dont see a problem there
ETC activates when there is a speed difference between left and right wheel on the axle (both front and back btw)
With a full locker engaged there is no speed difference so that axle will not activate the etc
Eg rear ARB, the ETC will only engage on the front axle (eventually blowing the 2pin front diff but that is another story)
With ATB (torsen LSD's) diffs the ETC will engage much less and if then it is supporting the functionality of the ATB's. So it is a benefit having ETC.
see also my topic here in the video's the difference with and without ETC is visible.http://www.defender2.net/forum/topic13545.html
Even with ETC it is a 5 euro, 10 minute job to fab a switch in line with the ETC/ABS fuse so you can manualy switch off both systems where advantageous, eg sand and sliding mud slopes. Personally i would even route this over a relay activated together with the ARB signal, so if you switch on the ARB, the ETC is automatically disabled (as on G-wagons where ESP and ABS are disabled)
Note also ETC does not work going backwards.
The benefits of having ETC and ABS in everyday situations are a no-brainer to me, for my type of driving.
Also consider resale value in your decision.
2 cents only
Smile
Post #152864 30th Jun 2012 1:36pm
ronwong
can you confirm that the ETC compnents are only in the front axle? abs is definitely in 4 wheels, else you cant call it abs.
because my current ride uses dana44 which there are a bunch of lockers available, but my understanding, usually with thinks like factory installed lsd or any form of esp or etc or such, its some how all linked up, and you cant really like plug out the carrier and swap in the arb carrier in the axle, there are other stuff and sensors etc that may not work or get in the way?
abs, etc, and all the crap if I am getting a salon, but hey, I dont get a defender to be on the tarmac, i would want to go front and rear locker in the end if possible. Anybody here fits lockers, i dont think its not common?
Post #152878 30th Jun 2012 3:08pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I would have thought all the axles are the same etc or not, the only differances being mountings for the wheels speed sensors.
afaik etc simply uses the ABS brake modulator to brake the spinning wheels, there shold be no differances in the diffs etc.
Jonno
Post #152895 30th Jun 2012 4:40pm
ronwong
if thats the case, i will go for the 110xs, which has etc, and at least it is better than open diffs. winch will come next and when ready, front and rear arbs... yoohoo
Post #152897 30th Jun 2012 4:50pm
